Sway Bar for Ek hatch
Re: Sway Bar for Ek hatch (Voyage34)
if you have the gsr rear sway bar (14mm) it will fit...you will need d-brackets and 99-00 si endlinks...you can still use your existing rear lower control arms
as for front sway bar...if you going to use 99-00 Si (26mm) you will need forks and lower control arm...i think that it...i cant remember what esle...Si Sway bar of course...
i think 96-00 Civic Ex (22mm) bolt right in...i think
Modified by JDMFreak at 7:36 PM 8/10/2006
Re: Sway Bar for Ek hatch (JDMFreak)
its the rear sway bar and i have megan racing lcas on my car now i know the d brackets dont work but it doesnt look long enough when i place it on the back of my car
^^^^ thats the GSR sway bar
im thinking of getting a si one
Re: Sway Bar for Ek hatch (Santys EK...905)
^^ doesnt look long enough how? the ends dont line up with the hoes in the lca's?
what endlinks are you using? ok an ek chassis you need to use the 99-00 si (em1) endlinks or equivalent aftermarket on all oem bars
RedGSR
06-10-2004 01:57 PM
Amuse9
12-30-2002 12:48 PM
