b18c1 in 92 cx using civic harness
Old Mar 30, 2006 | 10:33 AM
HondaInteg95's Avatar
Default b18c1 in 92 cx using civic harness
Ok I got my b18 in from my 95 gsr and found out i couldn't use the b18 engine harness with the civic because no power was going to my ecu. (gsr ecu plugged in) So now I have my d15 wiring harness plugged into my b18 and the car runs but how do I add vtec now.
From my understanding all 92 civics were pre wired for vtec so do I just run a wire from the engine harness to the vtec selenoid or do i need to run a wire directly to the ecu.
scott
Old Mar 30, 2006 | 02:15 PM
Default Re: b18c1 in 92 cx using civic harness (HondaInteg95)
bump^^^^^^
Old Mar 31, 2006 | 09:12 AM
anyone bump
Old Mar 31, 2006 | 05:45 PM
lsvtecracer's Avatar
You should have been able to use the gs-r harness with no problems. Is it a complete harness and did you check to make sure you plug up the power wires to the fuse box?
Old Apr 1, 2006 | 12:16 PM
Default Re: b18c1 in 92 cx using civic harness (lsvtecracer)
Yeah it was all plugged in right but I believe the gsr harness wont work with the civic cx- I know hasport sells a different harness for the cx.
bigboi408
18
Nov 1, 2020 11:42 AM
4g4dcruisin
Mar 12, 2010 04:25 PM
b20beast978
23
Jun 11, 2007 09:52 AM
boostmywankle
10
May 22, 2005 12:31 PM
Homericaeast
May 21, 2002 07:06 PM
