light problem
Old Mar 30, 2006 | 09:21 AM
Ha Itz's Avatar
Default light problem
i got a problem with my headlights that i need some help on. For the past few months only my left head light works under low beams but when i use the high beams both work. But now the left went out when i use the low beams but it works under low.. so basically now the left works under low...and the right doesnt and vice versa when i put the high beams on..i changed all the fueses out and still it does teh same thing. does anyone have anymore suggestions?
Old Mar 30, 2006 | 09:27 AM
AutoXer's Avatar
Default Re: light problem (Ha Itz a Jew)
Have you replaced the bulbs and checked the wiring harness?
Old Mar 30, 2006 | 09:30 AM
Ha Itz's Avatar
Default Re: light problem (AutoXer)
yea i replaced the bulb and its still the same i messed around with the wires and it worked for like 5 mins but then it went right back to the same ****
tylerstephen11
Sep 7, 2018 03:37 PM
GetEfdupEH
Lighting
Sep 3, 2009 05:15 AM
getnasty
May 31, 2005 03:04 PM
combustion
Aug 20, 2002 09:54 PM
