EG Hatch headlight problem
I just recently hooked up a pigtail to my wiring harness in my 92 Si for my RIGHT headlight.
There is a problem and I was wondering if anyone could help me out.
When my dim lights are on, the left light is on dim but the right light is on bright.
When I flip my brights, the left works fine but the right light doesnt work at all.
There is obviously a wiring problem but I do not know where.
Help anyone? Thanks.
Re: EG Hatch headlight problem
One of these. With the exception that mine has 3 wires coming out. High. Low. Ground
Explained: There was a terrible HID job on the car when I bought it so I wanted to put regular lights back in. Left light had the plug and went right together.
Right light however was spliced together and was just a MESS in general.
I found a diagram of a 9003 plug and it looks like this:
Also by my understanding, the wire colors are as follows:
red/white = low beam
red/blue = high beam
black = ground
any problems there?
black = ground
any problems there?
If you just apply simple logic to the behavior of your lights, I think you will agree that most likely:
Simple voltage tests could verify my theory. Also check whether 10A dash fuse 9 is blown.
Simple logic paid off!!!
Found the problem.
First...the red/blue wire was cut and hidden by electrical tape.
Second...I used the blue wire with a red stripe instead.
Thanks Ron. You're a legend!
Found the problem.
Lou_EM1
07-05-2007 03:08 PM
