Honda S2000 Honda S2000
check engine light
Old Mar 29, 2006 | 01:09 PM
yellows2k's Avatar
Default check engine light
has anyone gotten a check engine light when u put an aftermarket headers? any help would be good thanks
Old Mar 29, 2006 | 01:10 PM
Negs's Avatar
Default Re: check engine light (yellows2k)
'You got everything bolted up correctly and sufficiently? Check again.
Old Mar 29, 2006 | 01:11 PM
yellows2k's Avatar
yup i did it 3 times and still came on
Old Mar 29, 2006 | 01:14 PM
yellows2k's Avatar
do u take the metal gasket out ? or no because i left it in with the other one that comes with the kit .
Old Mar 29, 2006 | 01:33 PM
Mr. Projekt's Avatar
* B A N N E D *
You're supposed to replace the gasket, for one, but that wouldn't throw your CEL. Check the O2 sensors.
Old Mar 30, 2006 | 06:42 AM
Nishant's Avatar
Default Re: check engine light (ProjektSlideways)
check 02 sensors. if everything is fine, go ahead and reset ecu. See if the cel comes back
Old Mar 30, 2006 | 01:24 PM
yellows2k's Avatar
Default Re: check engine light (Nishant)
i think im going to autozone an get the code and see what happens and go from there.
Old Mar 30, 2006 | 02:17 PM
LBBP R's Avatar
check o2... 99% percent, ppl forget to plug sensor back on.
Old Mar 30, 2006 | 02:58 PM
WowOzYouRock's Avatar
Default Re: check engine light (LBBP R)
make that 98% cuz i didnt forget mine
prwittman
Jul 13, 2018 01:00 PM
luvinmyGSR
Aug 26, 2004 08:27 PM
CDN Yellow ITR
Apr 25, 2004 01:01 PM
B18EG6
Sep 1, 2002 08:15 AM
mb97civicex
Apr 22, 2002 12:10 PM
