speedometer problem
Old Mar 29, 2006 | 09:30 AM
Terrible One's Avatar
Default speedometer problem
93 civic hatch w/ jdm h22a swap
stock cx tach, speedometer works but reads 10mph over, so if the speedo reads 45 im actually going 35. i swapped a different gauge cluster and it does the same thing so its definately not the cluster. could it be something else like the cluster wiring or speed sensor? i havent checked the sensor on the tranny yet but was wondering if anybodys had the same problem where it reads 10 over?
Old Mar 29, 2006 | 10:43 AM
saywhat's Avatar
Default Re: speedometer problem (Terrible One)
bump for a local.
Old Mar 29, 2006 | 11:03 AM
TheWelderGuy's Avatar
i have that problem too man, except mine is 20 over. as soon as i put the car on acc it goes right up to 20kmhr, i never ever tryed to fix it but i was wondering the same, let me know if ya get it figured out
Old Mar 29, 2006 | 11:27 AM
lonefuzzy79's Avatar
Do you have 17s or 18s? Have you changed the overall diameter of your wheels? Things to ponder.
Old Mar 29, 2006 | 08:43 PM
Default Re: (lonefuzzy79)
rolling on 15's, 195/50 tires
Old Mar 30, 2006 | 06:15 AM
Default Re: (Terrible One)
bump
Old Mar 30, 2006 | 08:12 AM
fmrprojects's Avatar
i had the same problem in my cx before and i just changed the cluster to a ex and it was fine
Old Mar 30, 2006 | 08:37 AM
Default Re: (fmrprojects)
i used a different cluster and it had the same problem. i'll check the speed sensor on the tranny when i have time, hopefully its just a loose connection
Old Mar 30, 2006 | 10:44 AM
ttt
Old Mar 30, 2006 | 08:40 PM
up
Old Mar 30, 2006 | 08:46 PM
j-bird's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lonefuzzy79 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have 17s or 18s? Have you changed the overall diameter of your wheels? Things to ponder.</TD></TR></TABLE>
Wouldn't be the tires because it sounds like its a constant 10 over, tire diameter would be a % instead.
Old Mar 30, 2006 | 09:01 PM
Default Re: (j-bird)
bumppp
Old Mar 30, 2006 | 09:32 PM
bump b4 bed
Old Mar 31, 2006 | 09:33 AM
Old Mar 31, 2006 | 08:43 PM
bump 4 help
Old Apr 1, 2006 | 05:15 AM
ttt
Old Apr 1, 2006 | 04:25 PM
up up up
Old Apr 1, 2006 | 05:56 PM
professor poon's Avatar
http://www.blackrobotics.com/yb_home.htm
blinger
11
Mar 26, 2024 08:08 PM
jerry_ort007
Feb 17, 2009 07:00 AM
darkwater_ghost
Dec 21, 2008 01:13 PM
sneakerfern
Nov 6, 2008 03:41 PM
importimage
10
Apr 15, 2004 01:34 AM
