can a d15 non vtec wiring harness work with a b16 swap?
Old Mar 27, 2006 | 04:36 PM
msinsky14's Avatar
Default can a d15 non vtec wiring harness work with a b16 swap?
like the title says........its a 1995 honda civic hatch with a jdm b16a swap........can I use the stock wiring harness on the b16a swap, since it will be on the wrong side if I dont........if not, what other harness could I use with the swap?
Old Mar 27, 2006 | 04:50 PM
f2m0u5's Avatar
Default Re: can a d15 non vtec wiring harness work with a b16 swap? (msinsky14)
You can reuse your stock harness or go with a EX or Si harness so you wont have to go through the hassel of wiring vtec, knock sensor, etc..
Old Mar 27, 2006 | 05:40 PM
msinsky14's Avatar
Default Re: can a d15 non vtec wiring harness work with a b16 swap? (0LlY)
WOW.......i had no clue that using a USDM vtec harness, then u didnt have to wire for vtec, or knock sensor, etc.........thanks a lot, if you have any more info on this please send it to me!!
Old Mar 27, 2006 | 05:53 PM
f2m0u5's Avatar
pm'd
hatch b16a guy
Jul 15, 2007 08:25 PM
17
Jul 10, 2006 08:51 PM
fwdftw
Mar 6, 2005 10:09 PM
importlegions
Sep 5, 2004 07:58 PM
hatchdrvr
Jul 21, 2002 09:39 AM
