Car won't start!!!
Old Mar 26, 2006 | 03:10 PM
prelude1897's Avatar
Default Car won't start!!!
Well, my brothers car won't start right now. He drives a Mazda Mellinia and the thing won't start up. We've replace the cap, rotor, and plugs, and still nothing. I took the first plug wire out to test if it was getting spark, and nothing. I'm not seeing any kind of spark, so what could it possibly be? I'm thinking it could be the whole dizzy, but I'm not sure. We don't wanna spend money on things we don't need, so I'd figure I'd get another opinion....Can anyone help a brotha out
Modified by prelude1897 at 4:38 PM 3/27/2006
Old Mar 26, 2006 | 03:32 PM
The Weather Man's Avatar
a Mazda.
hehe. Its a Ford, thats why it won't start
Anyway, put the spark plug on the wire - put it in the cylinder half way.........have someone crank it over while you have your finger tip on the wire. You should be able to feel the spark (a popping feeling). If not, then your dizzy could be messed up. But make sure you're getting good fuel and compression.
Old Mar 26, 2006 | 04:13 PM
Default Re: (The Weather Man)
Well, I put a screw driver into the plug wire and sat it close to a piece of metal on the motor, and didn't see any spark....
Old Mar 26, 2006 | 04:34 PM
SteveoBA8's Avatar
Default Re: (prelude1897)
Get a multimeter(dvom) or testlight(not accurate) and make sure your getting 12v to the dizzy.
Old Mar 26, 2006 | 06:33 PM
CivicSiDriver02's Avatar
Default Re: Car won't start!!! (prelude1897)
Make sure the coil is still working too.
Old Mar 26, 2006 | 08:45 PM
Default Re: Car won't start!!! (CivicSiDriver02)
How can I test the dizzy to be sure it's working fine?
Old Mar 27, 2006 | 07:44 AM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
try banging on the starterneer where the teeth are. sometimes the starter's teeth will get stuck. thats what happened to me after not starting my car for a month. that also depends if you live in a cold area
Old Mar 27, 2006 | 08:06 AM
Default Re: (h22boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22boy &raquo;</TD></TR><TR><TD CLASS="quote">try banging on the starterneer where the teeth are. sometimes the starter's teeth will get stuck. thats what happened to me after not starting my car for a month. that also depends if you live in a cold area</TD></TR></TABLE>
I tried that, and still nothing happened.....
Old Mar 27, 2006 | 08:26 AM
98vtec's Avatar
moderator emeritus
theres a couple reason to why you wouldnt be getting spark:
ignitor
bad cap/rotor
fried coil
fried dizzy
For some reason i'm leaning more towards the coil. The coil is what sends power to the dizzy. If that is gone...you will have no spark.
Old Mar 27, 2006 | 09:38 AM
brolli's Avatar
Default Re: (98vtec)
yea...ok you said it wont crank over. and your testing for spark?? ur kiddin rite. by saying the engine wont crank your referring to the fact that when you turn the key to start the engine the crankshaft isnt rotating.
Old Mar 27, 2006 | 01:38 PM
Default Re: (brolli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brolli &raquo;</TD></TR><TR><TD CLASS="quote">yea...ok you said it wont crank over. and your testing for spark?? ur kiddin rite. by saying the engine wont crank your referring to the fact that when you turn the key to start the engine the crankshaft isnt rotating.</TD></TR></TABLE>
My bad, I edited it for you guys. It cranks, it just doesn't start
Cameron60
Feb 19, 2009 10:22 PM
h22lude317
Feb 18, 2009 11:03 AM
Tad
Sep 5, 2007 09:51 PM
AIWFCIATR
Jul 23, 2004 11:54 PM
irdprelude
Jan 24, 2003 05:54 PM
