Hard to start when cold...
I just bought this 87 prelude. It doesn't want to start when the motor is cold. I have to step on the gas pedal all the way down and then it will fire up, sputter and die. I do this about five times and then play catch with the idle as its falls I give more gas. Is this a common ailment? Once the motor warms up it starts fine though. It also idles at around 1300 rpm when warm. I also noticed after a long drive it continues to idle after being turned off. Again, any common problems that I can fix? Thanks.
kim_2_da_chee
Mar 2, 2005 12:02 AM
