cx swap
hey guys im lookin to buy a 92-95 cx and put my d16z6 in it out of my ex (that is toteled do to people not stop at red lights...( is this going to be a plug and play swap or do i have to wire anything in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DoorBandit »</TD></TR><TR><TD CLASS="quote">even if i use the ex engine harness and ecu i still have to run wires for it</TD></TR></TABLE>
This is true.
Unless its a '92. Then the main harness is pre-wired for vtec.
Otherwise you will need to run two wires for the passenger strut tower into the ecu plugs.
This is true.
all you have to run is 3 wires. 1 ground and 2 to the ECU. its really easy. good luck
if i use the ex engine harness do i need to run the ground or just the solinoid and pressure switch+
i already pullled the wires out of my ex that run to the ecu but i only pulled two not the ground
T-RO
Aug 6, 2008 03:10 PM
