Two plugs on the back of the block
Old Mar 25, 2006 | 01:45 PM
bmiller17's Avatar
Default Two plugs on the back of the block
Anyone know what the single wire plug and the blue plug are, on the back of a d16y8 block?
Old Mar 25, 2006 | 03:12 PM
bmiller17's Avatar
Default Re: Two plugs on the back of the block (bmiller17)
bump
Old Mar 25, 2006 | 03:22 PM
Silverhatch's Avatar
single wire is the knock... the other one might be the oil sending unit
Old Mar 25, 2006 | 03:24 PM
bmiller17's Avatar
Default Re: Two plugs on the back of the block (Silverhatch)
what would happen if i didnt have those hooked up?
Old Mar 25, 2006 | 04:27 PM
96ex's Avatar
If you don't have the knock hooked up wouldn't it throw a cell?
Old Mar 25, 2006 | 05:41 PM
bmiller17's Avatar
Default Re: Two plugs on the back of the block (96ex)
Yeah, it threw a cel, but was just wondering if i hooked it up...what will it change?
Old Mar 25, 2006 | 07:34 PM
IOSUA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmiller17 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, it threw a cel, but was just wondering if i hooked it up...what will it change?</TD></TR></TABLE>
yeah, if you wire up that knock sensor, the cell should go away. just run that wire to your ECU.
Old Mar 25, 2006 | 07:38 PM
SOHC4life 96's Avatar
Default Re: Two plugs on the back of the block (jdm dc2 01)
Other than the car not being in limp mode and the CEL going away, nothing. The oil pressure sending unit wire is useless acutally. It controls the idiot light and if that light comes on, your engine is LONG gone. So what I'm saying in a nutshell, hook up the knock sensor and it is your choice to hook up the oil pressure sending unit.
Old Mar 25, 2006 | 08:42 PM
bmiller17's Avatar
Default Re: Two plugs on the back of the block (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
Other than the car not being in limp mode and the CEL going away, nothing. The oil pressure sending unit wire is useless acutally. It controls the idiot light and if that light comes on, your engine is LONG gone. So what I'm saying in a nutshell, hook up the knock sensor and it is your choice to hook up the oil pressure sending unit.</TD></TR></TABLE>
thanks for the help man
mouab18c1
Mar 26, 2008 09:50 AM
00000xxx
Dec 18, 2004 08:09 AM
SleeprCivic
Jun 21, 2004 11:14 AM
lsvtec101
Jun 17, 2004 10:22 AM
rudebwoy
Dec 30, 2003 01:46 PM
