Battery light constantly on, where should I buy an Alt from?
My battery light started coming on today and now it stays constantly lit. I also notice my cluster lights are dimmer and so are my headlights. So I was a good nub and I searched.....and I guess my alternator is going bad. I am going to AZ tomorrow to have it checked out so my question is this: Where should I get the new Alt from? In addition, should I replace belts while I am in there?
is there a way I can manually spin it? I was loose before (bad squeak on a cold start) so I loosened the bolt holding the alt and put a wrench in the space, pulled back as hard as I could (to tighten the slack) and tightened the bolt for the alt back down. Now it is so loose it is not even catching (suprised the belt is still on).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net »</TD></TR><TR><TD CLASS="quote">is there a way I can manually spin it? I was loose before (bad squeak on a cold start) so I loosened the bolt holding the alt and put a wrench in the space, pulled back as hard as I could (to tighten the slack) and tightened the bolt for the alt back down. Now it is so loose it is not even catching (suprised the belt is still on).</TD></TR></TABLE>
If its that loose, its probably not your alternator, its just the belt. Tighten it the same way you did before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">If its that loose, its probably not your alternator, its just the belt. Tighten it the same way you did before.</TD></TR></TABLE>
Think I should put some blue threadlocker on there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net »</TD></TR><TR><TD CLASS="quote">Think I should put some blue threadlocker on there?</TD></TR></TABLE>
You shouldn't need to. Use a breaker bar or a long pipe so you can get leverage and tighten it down.
Tim 95 M3
Mar 12, 2009 02:17 PM
ch4nq
Jul 20, 2004 07:02 PM
