Battery light constantly on, where should I buy an Alt from?
Old 03-24-2006, 07:31 PM
o2flow.net's Avatar
Default Battery light constantly on, where should I buy an Alt from?
My battery light started coming on today and now it stays constantly lit. I also notice my cluster lights are dimmer and so are my headlights. So I was a good nub and I searched.....and I guess my alternator is going bad. I am going to AZ tomorrow to have it checked out so my question is this: Where should I get the new Alt from? In addition, should I replace belts while I am in there?
Old 03-24-2006, 07:46 PM
fmrprojects's Avatar
Default Re: Battery light constantly on, where should I buy an Alt from? (o2flow.net)
are you even sure you have a alternator belt on there
Old 03-25-2006, 01:05 PM
o2flow.net's Avatar
Ok, how tight should I make the new belt?
Old 03-25-2006, 01:10 PM
swifty4u's Avatar
Default Re: (o2flow.net)
Until there is no slack, but not so tight it can't spin.
Old 03-25-2006, 01:29 PM
o2flow.net's Avatar
Default Re: (swifty4u)
is there a way I can manually spin it? I was loose before (bad squeak on a cold start) so I loosened the bolt holding the alt and put a wrench in the space, pulled back as hard as I could (to tighten the slack) and tightened the bolt for the alt back down. Now it is so loose it is not even catching (suprised the belt is still on).
Old 03-25-2006, 01:32 PM
HT Order of Merit
JDM_Ej's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net &raquo;</TD></TR><TR><TD CLASS="quote">is there a way I can manually spin it? I was loose before (bad squeak on a cold start) so I loosened the bolt holding the alt and put a wrench in the space, pulled back as hard as I could (to tighten the slack) and tightened the bolt for the alt back down. Now it is so loose it is not even catching (suprised the belt is still on).</TD></TR></TABLE>
If its that loose, its probably not your alternator, its just the belt. Tighten it the same way you did before.
Old 03-25-2006, 01:35 PM
o2flow.net's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">If its that loose, its probably not your alternator, its just the belt. Tighten it the same way you did before.</TD></TR></TABLE>
Think I should put some blue threadlocker on there?
Old 03-25-2006, 01:36 PM
HT Order of Merit
JDM_Ej's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net &raquo;</TD></TR><TR><TD CLASS="quote">Think I should put some blue threadlocker on there?</TD></TR></TABLE>
You shouldn't need to. Use a breaker bar or a long pipe so you can get leverage and tighten it down.
Old 03-25-2006, 01:52 PM
riceburnerryan's Avatar
yeah dont buy an alternator if you dont have to. it would be a waste, just try and get that belt tighter
Old 03-28-2006, 07:24 PM
o2flow.net's Avatar
Thanks guys, I cranked that bitch down tight, no squeaks or dummy lights now
ElCivic89
03-27-2012 08:23 PM
Tim 95 M3
03-12-2009 02:17 PM
DmcL
11-30-2006 07:28 AM
ch4nq
07-20-2004 07:02 PM
onyx00
12-09-2002 09:09 AM
Quick Reply: Battery light constantly on, where should I buy an Alt from?
