Sluggish accelerator...
Old Mar 24, 2006 | 06:47 AM
brockscivic's Avatar
Default Help me figure this out...
Ok straight to business...
D15b7/s20 ex tranny
AEm cam gear
d16a6 cam
z6 intake manifold
OBX header
Airmass exhaust
G-sport cap and rotor (sucks ***...blue corrosion everywhere)
NGK plugs and wires
Now after i swapped the cam seal and cleaned the terminals on the cap with a knife I lost power...it accelerates slowly (i know its a b7 but it pulled very hard before this install). When you push the pedal in to give it more gas it sounds like its t hrowing way too much gas in and not enough spark. Overall the idle is good, the car runs good, just has a lack of power.
Ive tried moving the cam gear one tooth retarded and advanced (both of which were worse). And Im at a loss...i need a checklist of anything and everything that could cause this lack of power that im having. Thanks guys
Old Mar 24, 2006 | 06:58 AM
mike1114's Avatar
Default Re: Help me figure this out... (brockscivic)
Replace cap+rotor. The contacts could be even worse now that you "tried" to clean them.
Did you move the distributor? This would throw the timing off and make the car run shitty.
Old Mar 24, 2006 | 06:36 PM
Default Re: Help me figure this out... (mike1114)
I didnt move it originally but i have since thinking i accidently through the cam off a little. But anyways bump for bed...help me make a checklist guys
Old Mar 24, 2006 | 06:41 PM
92hatchling's Avatar
get a new cap it will probly fix it and you didnt some how lose the spring in the cap the goes to the coil did you
Old Mar 24, 2006 | 06:46 PM
Raggedyman's Avatar
I had a problem exactly like that after changing plugs and plug wires.....seems I got 2 and 3 mixed up on the dizzy. Might want to double-check your wires and firing order on the dizzy.
Old Mar 24, 2006 | 07:14 PM
Default Re: (Raggedyman)
actually...i did lose the spring...and didnt notice it for about a week...i took one from an 88 dizzy and used it but it didnt help. And the firing order is correct.
Old Mar 24, 2006 | 09:19 PM
Default Re: (brockscivic)
just buy another cap and be done withit
Old Mar 25, 2006 | 03:55 PM
Default Re: (92hatchling)
i bought a cap/rotor and a timing light today and i got the ignition timing dead on. It runs a little better but its still sluggish.
The cap didnt include a spring...the spring is made onto the coil so i used a spare spring i had and jerry rigged it to fit...
would not having that spring for awhile make the coil go bad to the point where it causes me to lose power?
Old Mar 25, 2006 | 04:58 PM
BauleyCivic's Avatar
Risky Business
Where is it sluggish? Are you sure the cam gear is set at zero? Try maybe retarding the cam gear a little bit, like 3 or 4 degrees. Then set ignition timing to like 17 or 18 degrees. Lemme know how that does.
Old Mar 25, 2006 | 05:07 PM
Default Re: (BauleyCivic)
its sluggish all the time...and im not too sure about adjusting the cam because i didnt mess with it period besides sliding the belt on and off
Old Mar 26, 2006 | 06:39 PM
anyone?
Old Mar 28, 2006 | 06:00 AM
i think its the coil
ascarberry
20
Feb 19, 2012 07:49 PM
brockscivic
Mar 10, 2006 08:41 AM
Renegade
May 9, 2004 08:04 AM
b20ek
Jul 21, 2003 10:24 AM
redcxhatch
Dec 22, 2002 04:39 PM
