Stiff clutch
Old Mar 23, 2006 | 08:52 PM
strsi's Avatar
Default Stiff clutch
I have an '86 CRX as my beater car. When i bought it the clutch pedal took about an average amount of pressure to push in all the way.
Ive had the car for over a year now & the clutch pedal is now very stiff. In fact, lots of times I can't even push it all the way down because it is just to stiff. I just figured it was normal for this to happen.
But then yesterday the pedal actually felt normal again. I was able to push it down with out getting a leg workout.
But now, today, its very stiff again. Anyone know why that is?
Old Mar 24, 2006 | 02:53 PM
aarjosmos's Avatar
Default Re: Stiff clutch (strsi)
try bleeding the clutch, if that doesn't work try replacing the slave cylinder. and if that doen't work it might be something internal
Old Mar 25, 2006 | 04:55 PM
alpine_hikr's Avatar
Default Re: Stiff clutch (aarjosmos)
seeing how its an 86 it probably has has a mechanical clutch. The clutch cable may be binding or else your pressure plate/friction disc may be fubar. I would remove the inspection plate and see if there are fibery pieces of clutch material. Good luck
[713]
Jun 20, 2009 08:23 PM
batboyvaj
Sep 28, 2007 09:17 AM
Vtec_Dude
Jun 10, 2007 10:44 AM
InitialJRift
Sep 13, 2006 10:43 AM
Kermit EK
Jan 29, 2003 03:02 PM
