Steering wheel won't straighten itself
Old Mar 23, 2006 | 05:11 PM
I like my R's Avatar
Default Steering wheel won't straighten itself
After I'm done turning, the steering wheel doesn't naturally straighten itself like it should. I have changed the lower ball joints, upper control arms, and tie rod ends in the front in an attempt to fix this problem, but it still persists.
I recently got an alignment, and my caster is at 2.8 degrees on each side, so it's not that. Does anyone have an idea of what the problem is?
Old Mar 23, 2006 | 05:17 PM
Shawn C's Avatar
In The Garage
real stupid, but are your tires low on air??
Old Mar 23, 2006 | 05:41 PM
Default Re: (ShadyEH2)
I actually checked the tires too, and they were fine. Thanks for the suggestion though.
Old Mar 23, 2006 | 06:56 PM
cxSHOE's Avatar
Default Re: Steering wheel won't straighten itself (I like my R)
i assume you mean for example your doing a U turn and at the end of the apex you let go of the steeringwheel and push the gas pedal to make the steeringwheel spin and going straight?
sounds like a rack-pinion problem, might be the teeth getting stuck on something or needs lube or ???
Old Mar 23, 2006 | 08:42 PM
Default Re: Steering wheel won't straighten itself (cxSHOE)
That's exactly what I'm talking about. I'm not glad to hear it may be something with the rack itself.
Old Mar 23, 2006 | 09:03 PM
powersteer's Avatar
check those cheap ones 1st, which is ur toe.
if your toe-out is too much, that cld be the reason. reduce that, or set it back to factory specs for confirmation
Old Mar 23, 2006 | 09:07 PM
Default Re: (powersteer)
I just got an alignment, and toe is set to straight ahead. The car still does it. It stumps me.
Old Mar 23, 2006 | 10:12 PM
Mike K's Avatar
Default Re: (I like my R)
you need a rack. end of story.
Old Mar 24, 2006 | 07:22 AM
ericlee303's Avatar
Mine does that too, but maybe not to the same extent your's does. I was wondering the same thing, but I think mine might be tow-related.
Old Mar 24, 2006 | 07:56 AM
YumVTEC's Avatar
Default Re: (Mike K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K &raquo;</TD></TR><TR><TD CLASS="quote">you need a rack. end of story.</TD></TR></TABLE>
that's it. i slid on some ice a long time ago in my gsr and hit a curb pretty hard, bent a tie rod pretty bad. had it replaced and the car re-aligned, and when I would turn the steering wheel, it would not re-center itself with throttle input at all. it was because the rack was damaged.
Old Mar 24, 2006 | 01:20 PM
bengay's Avatar
Default Re: (YumVTEC)
im having the same problem. i have an uneven kaster, passenger is at 3.2 n driver is at 2.2. was wondering if u got it fix yet???
Old Mar 24, 2006 | 02:47 PM
Nick MC's Avatar
Default Re: (bengay)
Caster is what centers your wheel and is an angle thats built into your steering knuckle( difference in degrees from the point of where the strut bolts to the knuckle to your lower ball joint if you were looking at it from the side.) You can't change that with an alignment if your caster's out your knuckles are bent. the only things alignments can fix are camber and toe. Caster can be effected slightly by changing those two things but not much.
Old Mar 24, 2006 | 03:57 PM
bengay's Avatar
Default Re: (KakarotITR)
so which part do i need to replace??
Old Mar 25, 2006 | 08:53 AM
Mike K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K &raquo;</TD></TR><TR><TD CLASS="quote">you need a rack. end of story.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K &raquo;</TD></TR><TR><TD CLASS="quote">you need a rack. end of story.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K &raquo;</TD></TR><TR><TD CLASS="quote">you need a rack. end of story.</TD></TR></TABLE>
Old Mar 26, 2006 | 07:49 AM
t o m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I like my R &raquo;</TD></TR><TR><TD CLASS="quote">After I'm done turning, the steering wheel doesn't naturally straighten itself like it should. I have changed the lower ball joints, upper control arms, and tie rod ends in the front in an attempt to fix this problem, but it still persists.
I recently got an alignment, and my caster is at 2.8 degrees on each side, so it's not that. Does anyone have an idea of what the problem is? </TD></TR></TABLE>
do you have an aftermarket steering wheel? maybe you tightend the spline nut too much
Dontoh
Suspension & Brakes
Aug 8, 2011 07:32 PM
bsmith100
Mar 10, 2010 01:10 PM
idano
Nov 29, 2006 02:10 PM
DudesHatch
Jul 27, 2004 06:44 AM
OneThirtyEight
Jan 22, 2002 06:44 PM
