TURBO INTEGRA PROBLEMS
Old Mar 23, 2006 | 12:11 PM
myst0ryman's Avatar
Default TURBO INTEGRA PROBLEMS
I have a 99 gsr integra turbo and i have a check engine light and it was a high input map sensor problem... can you guys help me out?? What does that mean?? and What can i do to fix it... NOTE I DO HAVE MISSING LINK, VTEC CONTROLLER, 12:1 FMU, AND A WALBRO 255 FUEL PUMP. PLEASE I NEED HELP
Old Mar 23, 2006 | 01:25 PM
1bad-eg's Avatar
Default Re: TURBO INTEGRA PROBLEMS (myst0ryman)
how many lbs. of boost r u pushing? I think that the missing link can only block a certain amount. Someone please correct me if I'm wrong.
Old Mar 23, 2006 | 01:52 PM
jdm'dc2sc61's Avatar
maybe it spiked a lil over 11 psi?
Old Mar 23, 2006 | 02:49 PM
myst0ryman's Avatar
Default Re: TURBO INTEGRA PROBLEMS (1bad-eg)
Im only pushing 5 psi with a t3 turbo
Old Mar 23, 2006 | 03:55 PM
T3mp3sT's Avatar
Make sure the filter didn't fall out of the missing link... it will create quite the vacuum issue and can allow damage to your MAP sensor.
Old Mar 26, 2006 | 11:52 AM
myst0ryman's Avatar
Default Re: (T3mp3sT)
Hey is there away i can get the filter becase it did fall out or is there something i can use to put into it???
Old Mar 26, 2006 | 01:41 PM
1DA94u2NV's Avatar
you can't use the stock map sensor on an engine which was not forced induction to begin with. it reads between usually .1 volts - 5 volts. (dc analog signal) boost will send a very high reading to the computer and your throttle response probly won't be what it should be. for faster throttle response and more accurate readings to the ecm you should get a performance MAF, not map. MAF is faster response time than MAP. good for forced induction
Old Mar 26, 2006 | 01:46 PM
TurboGS-R's Avatar
Default Re: TURBO INTEGRA PROBLEMS (1DA94u2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1DA94u2NV &raquo;</TD></TR><TR><TD CLASS="quote">you can't use the stock map sensor on an engine which was not forced induction to begin with. it reads between usually .1 volts - 5 volts. (dc analog signal) boost will send a very high reading to the computer and your throttle response probly won't be what it should be. for faster throttle response and more accurate readings to the ecm you should get a performance MAF, not map. MAF is faster response time than MAP. good for forced induction</TD></TR></TABLE>
I have a stock map sensor on my car running 11 psi on a T3/T04. I have a 3 BAR, but haven't installed it yet.
Old Mar 27, 2006 | 08:45 AM
myst0ryman's Avatar
Default Re: TURBO INTEGRA PROBLEMS (TurboGS-R)
bump
Old Mar 27, 2006 | 09:25 AM
gr_electronics's Avatar
replace ya OEM map sensor with a (MSD 3bar map sensor)
Old Mar 27, 2006 | 09:33 AM
myst0ryman's Avatar
Default Re: TURBO INTEGRA PROBLEMS (gr_electronics)
Thanks man but where can i get one of those??
Old Mar 27, 2006 | 09:45 AM
Dartanian's Avatar
Terrible advice thus far...
Get some real fuel management and not some hacked together ghetto **** and your problems will probably go away.
Old Mar 27, 2006 | 06:17 PM
TurboGS-R's Avatar
Default Re: TURBO INTEGRA PROBLEMS (Das Schmoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">Terrible advice thus far...
Get some real fuel management and not some hacked together ghetto **** and your problems will probably go away.</TD></TR></TABLE>
Are you talking about him getting an Electronic Management System or injectors (probably needs 440 cc) because Walbro FP and FMU seem all right to me?? I personally haven't had experience with using a vtec controller on a turbo Honda, but I've heard people have done it on low boost.
Old Mar 27, 2006 | 06:26 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGS-R &raquo;</TD></TR><TR><TD CLASS="quote">
Are you talking about him getting an Electronic Management System or injectors (probably needs 440 cc) because Walbro FP and FMU seem all right to me?? I personally haven't had experience with using a vtec controller on a turbo Honda, but I've heard people have done it on low boost. </TD></TR></TABLE>
Yes, I am talking about something that controls fuel and ignition electronically like Hondata, Crome, Uberdata, EMS, etc, etc.
How many times does it have to be beaten into people's heads that engine management is the most important part of any healthy turbo setup?
Old Mar 27, 2006 | 06:38 PM
JDMB20TDA's Avatar
How many times does it have to be beaten into people's heads that engine management is the most important part of any healthy turbo setup?</TD></TR></TABLE>
agreed
running that FMU is prolyl washing ur cylinder walls and when its not ur on the verge of det
there is no way of knowing whats going on with a <U>risky</U> fmu setup...
to half *** it untill u get tuning, buy a wide range a/f ratio sensor and ull see first hand the ishness of a Fmu...
please listen to these guys u dont wnat to det and pop a sleeve
chrisfromsrq
Sep 26, 2009 12:20 AM
EJ8 GSR-T
Nov 4, 2007 09:52 AM
nicktagz
Sep 8, 2006 11:01 AM
wshondaman
Dec 19, 2004 06:36 PM
_VTI-R_
Feb 26, 2003 01:12 PM
