D-Series to D-Series
Old Mar 23, 2006 | 07:46 AM
BoostFrenzy.com's Avatar
Default D-Series to D-Series
Tried searching but didn't find anything..
I have a 93 VX.. VTEC-E engine. Is switching over to a D15B or D16Z6 a straight forward hoist engine out, drop new engine in? Will I need other parts, besides a different tranny..
Thanks for any help guys.. appreciate it mucho!
Old Mar 23, 2006 | 07:48 AM
drewbie's Avatar
Default Re: D-Series to D-Series (Mafiozo)
Buy a new cam, and get some new engine managment. If you dont want to do that, Ill buy your motor.
Old Mar 23, 2006 | 07:50 AM
drewbie's Avatar
Default Re: D-Series to D-Series (drewbie)
For an engine swap, is a direct replacement. Everything goes in the same place. You might want to look into new motor mounts though,because the old ones will likey be worn.
And if you dont have a Si or EX transmission, get one. You will need it.
Old Mar 23, 2006 | 08:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewbie &raquo;</TD></TR><TR><TD CLASS="quote">For an engine swap, is a direct replacement. Everything goes in the same place. You might want to look into new motor mounts though,because the old ones will likey be worn.
And if you dont have a Si or EX transmission, get one. You will need it.</TD></TR></TABLE>
So I would only need the engine/transmission and nothing else? That's what I was getting at.. sorry if it wasn't clear.
Old Mar 23, 2006 | 08:19 AM
Saw a pretty nice deal for a d15b on Hmotors.. 435+shipping+150 for tranny..
Old Mar 23, 2006 | 10:14 AM
What ECU would I need with a D15B? Can I use a D16Z6 ecu ?
Old Mar 23, 2006 | 10:27 AM
Mooneyes13's Avatar
p08 for d15b (single wire o2)
Modified by Mooneyes13 at 3:40 PM 3/24/2006
Old Mar 23, 2006 | 06:46 PM
drewbie's Avatar
Default Re: D-Series to D-Series (Mooneyes13)
p28 for any VTEC engine. Like
Mooneyes13
p06 for any ohter D
Old Mar 23, 2006 | 06:51 PM
SovXietday's Avatar
The engine will drop right in and bolt up without problems. You want the EX/Si tranny for a Dseries (not the B16 tranny), they're the best Dseries trannies.
Old Mar 23, 2006 | 07:06 PM
vtecpoweredsol's Avatar
ya, the z6 ecu should be fine
Old Mar 23, 2006 | 07:09 PM
Everyones Hero's Avatar
Default Re: D-Series to D-Series (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">The engine will drop right in and bolt up without problems. You want the EX/Si tranny for a Dseries (not the B16 tranny), they're the best Dseries trannies. </TD></TR></TABLE>
Or he could use the Y8 transmission which has steel shift forks.
Old Mar 23, 2006 | 07:10 PM
BauleyCivic's Avatar
Risky Business
Default Re: (vtecpoweredsol)
https://honda-tech.com/zerothread?id=635782
Be sure to read this, lot of good info
Old Mar 24, 2006 | 01:04 AM
lemon_juice's Avatar
its a p08 ecu u want to get, not p06.
Old Mar 24, 2006 | 03:12 AM
fmrprojects's Avatar
Default Re: D-Series to D-Series (lemon_juice)
you are gonna have to repin the o2 wires going into the ecu
Old Mar 24, 2006 | 04:24 AM
loyalty4eva's Avatar
So to do this swap you have to get the p08 ecu? Im doing kinda the same thing i have the 94 CX and im going to be swaping in the y8 probebly.
Old Mar 24, 2006 | 05:07 AM
JabroninWARRIOR's Avatar
Default Re: (loyalty4eva)
i know i should just make my own post but it seems like people know what they are talking about in this one
i have a 92 vx and i'm swapping in a 95' cx motor.. i have the cx ecu and engine harness and will be re-using my vx trans with the cx motor
should everything be straight forward or will there be re-wiring needed like what i read above with the o2 pin. or was that only cuase it was using a dif ecu?
any light on the situation would be greatly apreciated
Old Mar 24, 2006 | 08:59 AM
92hatchling's Avatar
Default Re: (JabroninWARRIOR)
yes the p08 is the ecu for the d15b v-tec but p28 will work fine and is easier to find and for the other quisten about cx into vx yes it will be stright foward just use yor cx harness
Old Mar 24, 2006 | 02:15 PM
drewbie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JabroninWARRIOR &raquo;</TD></TR><TR><TD CLASS="quote">i know i should just make my own post but it seems like people know what they are talking about in this one
any light on the situation would be greatly apreciated</TD></TR></TABLE>
why? motor blow?
SharkEg
17
Mar 4, 2012 04:35 PM
PrimeElement
Sep 25, 2007 11:46 AM
notstreetlegal
Apr 10, 2007 09:34 AM
SystemAddict
20
May 1, 2002 01:46 PM
markedOO1
Nov 12, 2001 11:34 AM
