idle problems h22a4 obd1
Old Mar 21, 2006 | 06:43 PM
92hondalude's Avatar
Default idle problems h22a4 obd1
when i start my care it runs fine for a little bit (1 min maybe 2) then the idle starts jumping. i checked my cel and it eather said 10 and a 12, or 22 whitch is 10=Air intake tempeture. and 12=EGR valve and 22=vtec oil presure. I might have wired up the vtec oil presure switch wrong would that make my idle just and sometimes make my car stall.
If you read the helms it says the the EGR valve symtoms are "rough idel"(got that), "freguent stalling"(got that), and "misfire and rough idling(no miss fire but rough idling)"
do you think it could be my EGR?
Modified by 92hondalude at 7:30 AM 3/22/2006
Old Mar 22, 2006 | 02:48 AM
syntax.'s Avatar
Default Re: idle problems h22a4 obd1 (92hondalude)
yeah, i think its deff your egr. try making a blockoff plate and see if that solves it, and then if you want to keep the egr functional you have to figure out if you screwed up the vacuum hose routing or the egr itself is just bad.
Old Mar 22, 2006 | 03:30 AM
Default Re: idle problems h22a4 obd1 (syntax420)
im going to try and replace it today i have a extra one laying around
Old Mar 22, 2006 | 03:53 AM
syntax.'s Avatar
if the vacuum hoses are screwed up then installing a new egr wont solve the problem. The first thing to do is make a quickie block off plate using a few layers of tin from a soda can and see if that is even your problem.
Old Mar 25, 2006 | 04:59 AM
i replace it and the idle got a little better it not jumping or anything untill you try and drive it and the car bogs out and stalls.
now im getting code 10(TA) and code 22(vtec)
would me TA sensor make my car run like ****?
Old Mar 26, 2006 | 11:22 AM
ok now i fixed all the codes
now that i have no codes the car idles perfect.
but when it warms up and you just hit the gas and let off the it starts jumping up to 2000 then back down to 750 and just keeps repeating
Old Mar 26, 2006 | 02:43 PM
94Vtecluder's Avatar
Car not overheating is it? How's that radiator and hoses holding up?
Old Mar 26, 2006 | 02:48 PM
Default Re: idle problems h22a4 obd1 (94Vtecluder)
noep the car is not over heating
what do you mean how is my radiator and hoses holding up?
i guess they are doing good?
i think it might be air in the coolant and it is messing with my FITV and EACV. do you think this is my problem?
Old Mar 27, 2006 | 07:05 PM
bump need help on whats is making my RPM's jump just when i hit the gas
Jmx305
Oct 25, 2013 12:45 AM
integra15
Jun 23, 2010 02:30 PM
dizzyroc88
Jun 20, 2008 10:08 PM
drock305
Nov 7, 2007 06:56 PM
street_ride14
May 5, 2007 10:13 PM
