engine wont turn over ....
Old Mar 21, 2006 | 12:43 PM
ninety4lscoupe's Avatar
Default engine wont turn over ....
Yah i have a 95 civic ex ... this morning i went to start it up to go work and it wouldnt completey turn over ... It was cold out so i thought it was the battery , i jumped the battery and charged it up , it was still doing the same thing . So then i changed the cap and rotor .. Still nothing happend , then i decided to check for spark comming out of the spark plug wires ... no sparks ... i replaced the coil still no sparks and the car still didnt turn over .. i check the fuel pump and that was working to ... someone told me that its most like the Distributor ... could this be true ???
Old Mar 21, 2006 | 12:51 PM
imm0rt41's Avatar
Well if the fuel pump primes and the engine cranks, that only leaves power as the missing variable. I'd try another battery, try new wires/plugs, check the starter, swap the dizzy for a known good one, and the most overlooked is check your ignotion switch. My switch was bad a while back and it took me days to figure it out.
Old Mar 21, 2006 | 01:20 PM
Default Re: (imm0rt41)
where is the igniton switch located ???
Old Mar 21, 2006 | 02:47 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imm0rt41 &raquo;</TD></TR><TR><TD CLASS="quote">Well if the fuel pump primes and the engine cranks, that only leaves power as the missing variable. I'd try another battery, try new wires/plugs, check the starter, swap the dizzy for a known good one, and the most overlooked is check your ignotion switch. My switch was bad a while back and it took me days to figure it out. </TD></TR></TABLE>
Its cranking over, so he doesnt need a battery or starter and plugs and wires dont go bad overnight.
If he's replaced the coil and still not getting spark, 99% of the time its the ignition control module(its inside the distributor, held in by two machine screws and has 4 wires plugging into it).
Somalie187
Feb 17, 2013 12:47 PM
bnmm
Sep 26, 2011 07:24 AM
lilsol89
Jul 15, 2008 07:40 AM
DA_zooooms
May 12, 2008 07:16 PM
flip1199
Dec 12, 2006 12:24 PM
