new ek mini-me swap problems
well, I pulled off the head and found a crack in the #1 sleeve. It's a small vertical crack with a chipped off piece at the top. goes from the base of the sleeve, about 1/3 the way up on the outside. I can't see anything on the inside, but I'm guessing that's why I'm showing low compression numbers and blowing white smoke. 1--->4 174 174 200 200 psi its a 97 y7 with a y8 head and y8 head gasket. Any thoughts? should I try putting it back together and hope it was just an improperly seated headgasket, and maybe that crack has been there. or should I buy a new block. Any thoughts from you guys would be great
Thanks
Thanks
Kaitosenin
Sep 6, 2010 03:53 PM
young noob
Sep 20, 2006 01:57 PM
mike93eh
Jul 19, 2005 08:04 PM
