ITR won't start...any ideas
Old Apr 2, 2002 | 12:35 PM
J28S's Avatar
New User
Default ITR won't start...any ideas
Here's the deal. Battery is good, fuel is new and good, oil is fine, no electrical problems, plugs are good, plug wires are good, distributor is new/good, fuel pump is fine, fuel pressure is good, blah blah blah. The car will turn over, but will not start. There is a wierd vibration sound each time the car turns over. Any thoughts???
Old Apr 2, 2002 | 01:31 PM
TRAY's Avatar
Default Re: ITR won't start...any ideas (J28S)
Open up your distributor and take a look inside....On my b16 the screw came off and the rotor wasnt turning.
Old Apr 2, 2002 | 02:58 PM
CopperSol's Avatar
Same suggestion...take the distributor cap off and have a friend crank the motor, if the rotor doesnt spin, that means you're timing belt is broken. If that checks out, you might wanna do a compression test and make sure you dont have a compression leak. Are you positive that the ignitor isnt fouled? Check your wiring harness also make sure everything is connected. Do you have an MSD? If so, the MSD could be bad or the external coil could be bad or not getting solid contact. One other thing you might wanna check is if the plug wires are in the right firing order.
Old Apr 2, 2002 | 03:06 PM
RJL's Avatar
RJL
New User
Default Re: ITR won't start...any ideas (CopperSol)
check the 15 amp fuse under the hood for the fuel injection system
Old Apr 2, 2002 | 03:09 PM
Katman's Avatar
check your fuses. Especially the ECU fuse in the engine bay. Check your ground wires. Are you're spark plug wires plugged in their correct spots?
double check all your sensors -- make sure they're fully plugged in...some might look fully plugged in...but haven't been snapped' closed.
check the distributor like what the fella's above mentioned.
Got GAS?
Old Apr 3, 2002 | 12:44 PM
J28S's Avatar
New User
Thanks guys...I'll check everything out this evening. Thanks again!!!
JasinC19
10
Aug 27, 2015 08:16 PM
halcyon1138
Jun 18, 2010 08:35 PM
aguynamedpat
Jun 4, 2009 03:32 AM
Blk00EJ8
Apr 28, 2007 01:27 PM
97civicdx
Apr 17, 2003 03:09 PM
