2nd gear problem...
Old Mar 20, 2006 | 04:21 PM
jdm_DC2R's Avatar
Default 2nd gear problem...
heres a problem...hopefully its nothing major.. But when i drive normally, goin from 1st to 2nd, it goes nicely into 2nd gear and then into 3rd, etc. But when i downshift from like 3rd gear to 2nd gear, i can never get it into gear, it never wants to go into 2nd gear coming from 3rd gear or 4th gear. Any ideas whats going on? what should i check?
thanks.
Old Mar 20, 2006 | 04:27 PM
JjuuN R's Avatar
it's completely normal depending on how fast you are going while you're trying to downshift. it's pretty much just a saftey thing for your tranny...
Old Mar 20, 2006 | 04:41 PM
jdm_DC2R's Avatar
i dont think thats it....at any speed it will never go into 2nd gear coming from 3rd...whether i go like 50km/h or 10km/h..it will not go!
Old Mar 20, 2006 | 06:29 PM
totsie7944's Avatar
Default Re: (jdm_DC2R)
try pumping the clutch twice... and also give it a little gas to get the rpms up. Which I hope you do anyway before dropping down a gear.
Old Mar 20, 2006 | 09:54 PM
itr1244's Avatar
Default Re: (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">try pumping the clutch twice... and also give it a little gas to get the rpms up. Which I hope you do anyway before dropping down a gear.</TD></TR></TABLE>
you mean. a rev match
Old Mar 21, 2006 | 01:03 AM
egtwincam's Avatar
check your clutch hydraulics for leaks. if no leaks.. you probably got a worn 2nd gear syncho or shift fork.
Old Mar 21, 2006 | 07:33 AM
jdm_DC2R's Avatar
Default Re: (egtwincam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egtwincam &raquo;</TD></TR><TR><TD CLASS="quote">check your clutch hydraulics for leaks. if no leaks.. you probably got a worn 2nd gear syncho or shift fork. </TD></TR></TABLE>
im leanin towards the shift fork...since it goes into 2nd gear easily and nicely comin from 1st, but comin from 3rd, doesnt happen at all!
Thanks guys
Old Mar 21, 2006 | 08:37 AM
citrus3000psi's Avatar
Are you rev matching when you downshift? The shifter should however still go in, it'll just be jerking depending how hard you let out on the clutch.
Also try, the double clutching method or when your 3rd gear let out on the gas, the shifter should come of of 3rd gear freely without pusing in the on the clutch. Push in the on the clutch now and see if the shifter goes into 2nd.
808k20z3
Honda Civic (2006 - 2015)
Jan 21, 2007 10:55 AM
vietnogi
Feb 2, 2006 11:36 AM
slammeddelsol95
18
Jul 19, 2004 01:44 PM
wreckedagain
Nov 7, 2001 08:48 PM
