no more first gear
Re: no more first gear (slammeddelsol95)
try to put it into first with out the clutch (do not force just tap it ) if it grinds it is the sinkroll,if notthing happens then that means your sink is good so then try this, put it into a diffrent gear if it does not go into any gear then i would have to say it is you clutch so buy a new one. let me know what happens.
Electrician
Re: no more first gear (frostcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostcivic »</TD></TR><TR><TD CLASS="quote">1st gear is for suckers. start from second gear. </TD></TR></TABLE>
You're the one that posted about not making a "Type R" because it had a sticker on it. Please end yourself for saying what you said on this thread. Good day.
Now, for the issue on hand, we need more information. Did you force it into any gear without pressing the clutch or did you hear a grind? Can you place it on 1st gear (position)?
Re: no more first gear (one8toh8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one8toh8 »</TD></TR><TR><TD CLASS="quote">try to put it into first with out the clutch (do not force just tap it ) if it grinds it is the sinkroll,if notthing happens then that means your sink is good so then try this, put it into a diffrent gear if it does not go into any gear then i would have to say it is you clutch so buy a new one. let me know what happens.</TD></TR></TABLE>
what the **** is a sinkroll? synchro? as in synchronizer?
Electrician
Re: no more first gear (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
BWAHAHAHAHAHAHAHA. I didn't even read that. WTF is a sinkroll?
Re: no more first gear (Dimi)
its a new clutch it only has like 200 miles on it i just got one after winter im not buyin any more crap for that 1.5 ******* cuz my b16 is commin soon but i wanna sell the motor thats in my car to pay my dad back some i waz going over a bridge and i came to a light i didnt down shift cuz my gurl waz in the car n she hates the exhast the light changed yeah no first gear it feels like the gear block is on like the block hat doesnt allow u to shift back into first after ur moving let me know im clueless on this
First: Ditch your "gurl" if she can't handle a downshift.
Second: If I understand you correctly you tried putting it into 1st while rolling? Many people say it won't let you if you are rolling more than 10mph, mine won't let you do it if you're moving at all. Don't force it in, just slow as much as possible and ease it into 1st.
Third: Grammar owns you.
bwahaha...i had to read it like 20 times before i realized what he was trying to say.
Re: no more first gear (Phil DeVtec)
got pissed and tokk my linkage off and put it back on still had the smae problem then i jiggeled the shift around when trying to put it in first now it magically works thanx tho when it wouldent go into first i waz totaly stopped and i turned the car off and then back on still wouldent go in i thin k suttin waz stuck in the linkage or suttin who knows all i care about is it fixed
Electrician
Well we had a flood down here a few months ago and I definitely submerged the linkage under (pretty much doorline submerge). The next morning the linkage was stuck and coudn't get into any gear. After moving it a bit and rolling backwards, it came loose. I guessed the bushings seized.
Re: (Dimi)
do you happen to have a short shifter...i read somewhere on here that some shortshifters (if it cost less than 30 dollars...) dont line up 100% or cause excessive wear...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">You're the one that posted about not making a "Type R" because it had a sticker on it. Please end yourself for saying what you said on this thread. Good day.
Now, for the issue on hand, we need more information. Did you force it into any gear without pressing the clutch or did you hear a grind? Can you place it on 1st gear (position)? </TD></TR></TABLE>
you're an idiot. that thread's purpose was to make fun of another thread created by another user, it wasn't serious you tool.
engrish owns you
engrish owns you
