Help!! check engine light, cant figure it out please help!!!
Old Mar 20, 2006 | 01:09 PM
B18C1EF's Avatar
Default Help!! check engine light, cant figure it out please help!!!
i have a 94 ex coupe, its got aD16Y8 swap in it, when i got the car it had a ghetto wiring harness, OBD-2 injectors, alternator, and distributor, but it was all converted to OBD-1, it idled wierd but no check engine light, so i swapped all OBD-1 stuff on to it, Z6 engine harness, injectors, distributor, and alternator, and now it throws a check engine light, im not sure if its throwing a 1 or a 10, i know on obd-0 the light is on the ecu but obd-1 u jump it, so i did that and blinks once but its kinda long blink, not sure if its a 1 or a 10, 1 is the o2 sensor, which that was fine before the harness swap, and 10 is the air intake temp sensor from what ive seen on here, but i dont know what it is please help!
Old Mar 20, 2006 | 01:14 PM
O RLY's Avatar
Default Re: Help!! check engine light, cant figure it out please help!!! (B18C1EF)
One long blink would be 10, one short blink is 1. Just like two long blinks followed by three short ones is 23.
Old Mar 20, 2006 | 01:15 PM
gunnis's Avatar
Short blinks =1
Long blinks = 10
By the sounds of it, intake air temp.
https://honda-tech.com/zerothread?id=1171263
Old Mar 20, 2006 | 01:16 PM
B18C1EF's Avatar
Default Re: Help!! check engine light, cant figure it out please help!!! (O RLY)
k im pretty sure its 10 then, what the expletive is an air intake temp. sensor?
Old Mar 20, 2006 | 01:18 PM
gunnis's Avatar
It is exactly that, a sensor that measure intake air temperature.
I'm tryin to find a picture of it on your d16y8 for you....
O RLY's Avatar
Located on the back of the intake manifold I do believe. I could be wrong. The IM utilizes the IAT (Intake Air Temp), the MAP (Manifold Absolute Pressure), the IAC (Idle Air Controller), and the TPS (Throttle Position Sensor). Good luck!
Old Mar 20, 2006 | 01:22 PM
B18C1EF's Avatar
ok that would make sense, cuz i i have two extra plugs on the OBD-1 harness i couldnt find anyplace to plug in, maybe i just need to look closer, i thought it was that sensor on obd2 cars that just plugs right into the intake arm?
Old Mar 20, 2006 | 01:40 PM
B18C1EF's Avatar
k i cant figure it out, i just went and looked at it theres one on top of the IM which is map sensor, one on the back of the TB, and one on the back of the IM, which one is the Air intake temp?`
Old Mar 20, 2006 | 02:14 PM
B18C1EF's Avatar
????? someones gotta know????
Old Mar 20, 2006 | 03:44 PM
fmrprojects's Avatar
on the d16y8 i believe they were in the intake arm. and on the stock d16z6 it is on the back of the intake manifold. the only way to rig it is to get a IAT sensor from a obd 2 car and wire it up into the intake arm
Old Mar 20, 2006 | 04:12 PM
B18C1EF's Avatar
Default Re: Help!! check engine light, cant figure it out please help!!! (fmrprojects)
o well, it has the Y8 IM on it, im not to worried about it, it runs fine either way lol
techabe12
Sep 12, 2016 05:29 PM
MrWestCoast
Mar 18, 2013 03:04 PM
grdatech
Engine Management and Tuning
Oct 21, 2012 05:12 PM
mafiasutra24
Oct 9, 2008 10:34 PM
iluvmyEJ1
May 20, 2007 06:01 PM
