Catch can filling up with water??
My catch can is filling up with water. just seeing if its good or bad.
its a modified ebay one. 2 ports in and down filling with steel wool, one from back of block and one from valve cover. and its vented through a breather.
thanks
burke
thanks
burke
there isnt a whole lot, maybe like 3/4 in. no real nasty **** in there, but my clear lines are getting darker. i figured condensation. its been real cold around here like 20-30's. put maybe 600-800 miles on her
its normal especially if you live in colder climates. the warm vapours from the crank case will blow into the cold catch can/container and cause moisture/condensation.....
cool, thats what i wanted to here. so i should expect less water as the weather gets warmer, if it ever does! do you know youngstown has the 3rd least amount to sunny days, #1 is Seattle and i forget #2. i cant wait to get out of ohio
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdavis »</TD></TR><TR><TD CLASS="quote">cool, thats what i wanted to here. so i should expect less water as the weather gets warmer, if it ever does! do you know youngstown has the 3rd least amount to sunny days, #1 is Seattle and i forget #2. i cant wait to get out of ohio
now that's depressing... LANSING, MI isn't far behind...
</TD></TR></TABLE>now that's depressing... LANSING, MI isn't far behind...
