vtec troubleshooting question
Old Mar 18, 2006 | 05:58 PM
Nickyj1211's Avatar
Default vtec troubleshooting question
Yo, im trying to help out my brother with his 93 teg with a b16 sir2 swap. The vtec doesnt seem to be engaging at all and i was wondering if anyone knows how to check to see if its the solenoid. Does anyone know what the voltages should be and/or how else you could check to see if the solenoid needs to be replaced. I see three wires from the solenoid, a ground and two wires that run to the ECU. I rewired those and soldered them on for a better connection. I am assuming that the vtec isnt working at all cause the previous owner said that one day it just cut out when he was driving (recently). When i accelerate, there seems to be no change in rpm acceleration when i would expect for it to. Thanks
Old Mar 18, 2006 | 06:42 PM
mmuller's Avatar
Mad Scientist
Default Re: vtec troubleshooting question (Nickyj1211)
any CELs?
you can check the solenoid by giving it 12v and listening for a click; you can also hook up a vtec light to see if there is actual power getting to the solenoid.
so what vtec stopped working or..
Old Mar 18, 2006 | 09:29 PM
Nickyj1211's Avatar
Default Re: vtec troubleshooting question (mmuller)
no cels at all, but there really is no kick in like i have seen in many other cars with similar or better setups. I will try the 12v thing. So if i hear the click, i should assume that its working properly?
Old Mar 19, 2006 | 05:49 AM
mmuller's Avatar
Mad Scientist
of ot clicks you can assume that the solenoid is working, the vtec light is going to tell you if there is actual vtec activation.
swizz977
10
May 25, 2011 08:15 PM
vtieg6
Nov 7, 2009 08:16 PM
swappedcivic
Dec 14, 2004 08:30 AM
South Bay Surfer
23
Jan 2, 2003 04:42 AM
gsrhatch530
Mar 28, 2002 01:36 PM
