white smoke
Old Mar 18, 2006 | 10:24 AM
builtboostedteg's Avatar
Default white smoke
after the cars runs for a couple minutes white smoke starts coming out the exhaust. smalla mounts at first then increases. i checked the pistons and rings, all are fine. checked out the head and all seals and things seem to be fine. i was told that i might have a bad injector or resistor, but i don't know why that would be because the smoke is white, which usually means oil to my knowledge. anyone have any ideas as to what could be wrong?
if it is the injectors, then why is it smoking white? and where can i get the injectors or resistors inspected or tested? somewhere close to st louis
Old Mar 18, 2006 | 10:35 AM
b20integrapower's Avatar
Default Re: white smoke (builtboostedteg)
white ususally is burning coolant..maybe the headgasket is goin..
Old Mar 18, 2006 | 10:40 AM
xplanetearth420x's Avatar
Default Re: white smoke (b20integrapower)
is your car running rich?
Old Mar 18, 2006 | 11:33 AM
CleanLikeJdm's Avatar
Hype-R Stalker
..how did you "check" the rings and valve seals?
If it's too much fuel or something, go behind your car and see if you can smell fuel.
Old Mar 18, 2006 | 03:19 PM
R6E6I6D's Avatar
Default Re: white smoke (FlatBlackTeg)
nah white smoke is the evaporation of any liquids. if its cold out thats normal
blue is oil
black is usually lean/rich misfire or just shitty rich
check oil for contamination...make sure its not jsut a shitty batch of gas
dailyekhatch
Aug 15, 2011 06:45 AM
Tuner Eddy
13
Aug 6, 2005 11:31 AM
HBK_DAVIDDD
Jul 28, 2005 11:07 PM
SIK IN DA HED
Jan 6, 2004 09:24 AM
R-1303
Nov 26, 2002 01:41 AM
