inspection coming up
Old Mar 18, 2006 | 10:01 AM
a1320addict's Avatar
Default inspection coming up
looking for some experience.
i've got inspection coming up, and i'm trying to figure out a plan of action. im in nj.
2001 gsr....obd1 conversion harness running neptune.
i was at my friend's place yesterday, and was going through the inspection system with him on the computer in the shop. seems as if it is user selectable to either run a sniffer or the diagnostic port hook up. now he says, naturally if he just runs a sniffer on an obd2 car the state is going to inquire why there was no diagnostics done etc.
my question is this: what exactly will happen if he attempts to hook up to the port while i still have the p28 in?
i really would like to stay away from throwing in the old ecu and having to swap the injector clips.
any advice would be super helpful.
thanks
Old Mar 18, 2006 | 10:21 AM
Turbo-charged's Avatar
Default Re: inspection coming up (yehiknowrite)
it just "wont connect" with the obd1 ecu in there. since i live in maryland, and its impossible to pass inspection....im going to have to say im upset that you are complaining about swapping injectors and injector clips in md we have to go as far as R&R'ing turbo kits, engines, suspensions, etc. MD SUCKS
Old Mar 18, 2006 | 10:28 AM
hondaguyef's Avatar
Default Re: inspection coming up (Turbo-charged)
Yep, The machine says, "Can't connect". I just had the same problem here in DE w/ my 99' 4dr. I had to swap back to the obd2b ecu. It sucked and the car barely passed (check engine light came back on literally 10ft. after driving out of the inspectiojn lane). Good luck.
Phil
edit: why would you have to swap injector clips?
Old Mar 18, 2006 | 10:45 AM
Default Re: inspection coming up (hondaguyef)
im not complaining...i just want to take care of this in the most sensible way.
2000siturboR
Jan 30, 2008 08:08 PM
mattm868
Jun 25, 2007 11:22 AM
SoyMilk
May 27, 2007 04:19 PM
00Red_SiR
Dec 20, 2006 01:16 PM
Blk00EJ8
Jul 24, 2005 09:20 AM
