Hondata on a ob2 vehicle...........
Alright an s100 with boost option p28 on a 0b2 car. The car is throwing an SRS light and stays on solid, the check engine light is on using the jumper wire only flashes once for the 02. My 02s are brand new and it still comes on, I cant pull the airbag code cause its an ob2 port with an obd1 ecu. The scanner wont connect. Anyone out there with any ideas or advice?
actually could be a short to ground on one of those sensors. i've seen this a couple times on other vehicles when a test probe is used on a live ABS circuit.
