Hondata on a ob2 vehicle...........
Old Mar 17, 2006 | 12:42 PM
Drkaccrd's Avatar
Default Hondata on a ob2 vehicle...........
Alright an s100 with boost option p28 on a 0b2 car. The car is throwing an SRS light and stays on solid, the check engine light is on using the jumper wire only flashes once for the 02. My 02s are brand new and it still comes on, I cant pull the airbag code cause its an ob2 port with an obd1 ecu. The scanner wont connect. Anyone out there with any ideas or advice?
Modified by Drkaccrd at 1:23 PM 3/18/2006
Old Mar 18, 2006 | 07:47 AM
Drkaccrd's Avatar
Default Re: Hondata on a ob2 vehicle........... (Drkaccrd)
BUMP FOR HELP
Old Mar 18, 2006 | 10:00 AM
civicstar's Avatar
P28s are OBD1 ecus, it will throw 02 codes unless u get a Jumper to make it from 0BD2-1, Then THE wiring cancels out 1 o2 sensor.
Old Mar 18, 2006 | 10:10 AM
Drkaccrd's Avatar
Default Re: (civicstar)
so using the jumper harness I will be able to retrieve CELS & SRS codes with a scanner? Cause thats the problem Im having right now. I have an OBD2 car with a OBD1 ECU scanners wont connect because of that.
Old Mar 18, 2006 | 10:52 AM
8krdline's Avatar
Default Re: (Drkaccrd)
yea u need a ob2b to obd1 jumper harness
Old Mar 18, 2006 | 11:46 AM
Drkaccrd's Avatar
Default Re: (8krdline)
besides being able to pull any trouble codes can I have the emissions done as if it were ob2?
Old Mar 18, 2006 | 05:26 PM
civicstar's Avatar
like P28 usually doesnt have codes if u get the jumper, and it will pass emissions if u can make it pass the emissions part. but i should pass the CEL/Function part
Old Mar 19, 2006 | 03:42 AM
Drkaccrd's Avatar
Wait will that work still considering hondata already converted the P28 ports to OB2 female ends? If thats what the jumpers main purpose was then I guess Im SOL. There really is no way around it...
Old Mar 19, 2006 | 09:40 AM
Drkaccrd's Avatar
nevermind.... having hondata on an obd2 car means you wont be emissions compliant anymore...everyones solutions here were wrong...
glennsek9
Feb 6, 2012 11:47 AM
97ej6civic
Aug 14, 2009 03:46 PM
preludepower01
Jul 24, 2007 09:45 AM
Drkaccrd
Mar 18, 2006 09:26 PM
2dark2bslow
Jan 27, 2004 02:15 PM
