just boosted my 00 si, im now running into some kinks
i just boosted my b16 and what are some reason why white smoke would be coming out of the valve cover stem? i havnt put im o2 sensor on it yet but everything else looks good. i really need some help... any advise would be helpful.
5 lbs. shouldn't kill it as long as your sending enough fuel - it's hard to tell with the FMU though if you didn't have a wideband hooked up. Does it idle rough or have rough acceleration? If so, you probably blew one of the piston ringlands. I'd get a compression tester and check it out, if the difference between any of the cylinders is more than ~15-20 psi, you're probably going to need a rebuild.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotUrAvgSi »</TD></TR><TR><TD CLASS="quote">fmu needs to go asap</TD></TR></TABLE>
pelotudo
Sep 8, 2002 06:53 PM
. Does your car idle funny by chance?
