auto to manual swap on sedan - 99% done, got a linkage problem - TOO LONG
Old Mar 17, 2006 | 08:52 AM
hb_guy's Avatar
Default auto to manual swap on sedan - 99% done, got a linkage problem - TOO LONG
well i have my auto to manual swap 99% complete on my 91 ex 4 door. but when i went to connect my linkage to me tranny(its already connected to the chassis) it was too long by about 2 inches.
are all d series linkages the same(minus del sol)?? i got mine from image plus customs on ebay and they said it was from an ef? are 4 door linkages shorter?
any help please!!!
Old Mar 17, 2006 | 10:01 AM
hb_guy's Avatar
Default Re: auto to manual swap on sedan - 99% done, got a linkage problem - TOO LONG (hb_guy)
anyone
Old Mar 17, 2006 | 10:10 AM
Jonathan_ED3's Avatar
All 88-2000 D-series linkages are exactly the same.
My friend is using '98 DX on his '91 Sedan. And I've used EG linkage in my previous car.
You need to contact that seller and get a refund or something.
Unless it's an adjustable linkage....crank that thing down until it's the right length.
Old Mar 17, 2006 | 10:52 AM
hb_guy's Avatar
Default Re: (Jonathan_ED3)
well i just went out a bolted it up by the shifter area and measured how long it is and it is about 1 7/8" longer. i have thought of redrilling the two holes by the shifter but it seems like the hole the shifter goes thru will be too small, and no sawzall. hmm.....
cut and re weld? drill holes first?
think they sent me an integra linkage with a civic shifter by mistake?
Modified by hb_guy at 8:04 PM 3/17/2006
Old Mar 17, 2006 | 03:00 PM
hb_guy's Avatar
anyone?
Old Mar 17, 2006 | 04:43 PM
hb_guy's Avatar
bump
Old Mar 17, 2006 | 06:21 PM
wood's Avatar
If you aren't going to try and return the linkage, take the measurement to a REPUTABLE welder and have it shortened. I had to have this done on my son's 91 DX hatch when we converted from auto to manual with his b16a swap. Ask people you know for a good welder because I've heard if it isn't done correctly it can be bad news. Good luck to you , you're almost there!
Old Mar 18, 2006 | 04:19 AM
hb_guy's Avatar
going to the junkyard to get another one then compare
Old Mar 18, 2006 | 04:59 AM
ahthisguyhere's Avatar
well when you put in a b series its always going to be shorter you need the hassport linkage cause its already set up for the swap
Old Mar 18, 2006 | 05:22 AM
hb_guy's Avatar
Default Re: (ahthisguyhere)
well i have a mini me swap in there right now - no b series in this car. i just wondered if they sent me the wrong one.
Old Mar 18, 2006 | 05:46 AM
DelSolDon's Avatar
Default Re: (hb_guy)
if they did send you b-series linkage, you will probably be better off reselling the b-series and locating a d-series linkage. just an idea before you try to modify yours. if you do go the cut and reweld way, just make sure that you run a couple straight lines down the length of the linkage so that you can make sure that it is straight when you go to reattach it.
Old Mar 18, 2006 | 08:21 PM
hb_guy's Avatar
Default Re: (DelSolDon)
well i already got a d series one and it is about 2-3" shorter. i am going to take pics tomorrow and post, maybe we can know for sure if the other linkage is from a b series, cuz i know the one i pulled today is from a d.
Old Mar 19, 2006 | 01:24 PM
hb_guy's Avatar
ok here are the pics, the shorter one was the one i recently pulled yesterday from a 89 civic dx hb. the other one is the one i have bought from import customs in nc.
is it a b series one? if so what year? 90-93 maybe?
Weedydgaf
Aug 2, 2015 08:20 PM
omgwtfbbqcrx
Apr 24, 2006 08:16 AM
fujiwara takumi
Dec 30, 2005 02:27 PM
menkio
Oct 22, 2004 06:44 AM
RuthlessEF-9
16
Feb 28, 2003 11:29 PM
