help please
Old Mar 17, 2006 | 06:37 AM
specscow's Avatar
Default help please
ive searched and i was wondering if there are any write ups on how to change the oil pump on a d15 civc i was wondering if i will have to drop the engine on one side and also how hard is it to do this
any help will be apreciated
Old Mar 18, 2006 | 05:21 AM
specscow's Avatar
Default Re: help please (specscow)
bump for help
Old Mar 18, 2006 | 06:20 AM
specscow's Avatar
so no one has changed an oil pump on honda-tech?
Old Mar 18, 2006 | 06:42 AM
CBURKE's Avatar
Its not that bad. First you will have to remove all belts, oil pan, main pulley, side cover. You will want to put a jack under there somewhere to hold the motor up because you will have to remove the side motor mount. Be carefull where you put the jack and use a board on top of the jack. once the cover is off you will need to remove the timing belt and why your there you should replace your water pump and timing belt. Trust me you do not want to have to do this again. If you have any more ???? let me know.
Old Mar 18, 2006 | 02:35 PM
specscow's Avatar
Default Re: (CBURKE)
when you say main pully do you mean the balancer?
Old Mar 18, 2006 | 02:54 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
the main pully is tha one connected to your alternator belt
Old Mar 18, 2006 | 03:03 PM
specscow's Avatar
Default Re: (phyz)
about how long does this take
Old Mar 18, 2006 | 03:43 PM
schardbody's Avatar
ok, once you have it down to timing belt, remove the timing belt, take off the outer belt guide and then oil pump gear (the small one behind the crank pulley) then the inner belt guide. once you have it down that far its time to pull the oil pan. with the pan off take off the two 12mm bolts holding the pickup tube to the main girdle, then take the 5 12mm oil pump bolts and use a rubber mallet or wood block to tap the oil pump off the end of the crankshaft. reassembly is opposite. make sure to use new water pump and timing belt at the very least. i highly recommend doing the oil pan gasket as well.
Old Mar 18, 2006 | 11:57 PM
Default Re: (schardbody)
good advice
Old Mar 20, 2006 | 06:42 AM
specscow's Avatar
Default Re: (phyz)
does any one else have any other suggestions or is that about all i need to do?
rak511
Feb 26, 2014 04:02 AM
untitled23
Apr 12, 2010 03:08 AM
ej1_lsvtec
Feb 4, 2006 06:55 PM
technine
Jul 2, 2003 05:59 PM
