headlight problem, help!
ok so today when im heading to autozone to pick up some fuses, i turn on my driving lights, they work, then i turn on my headlights, and my gauge dims to no light, my speedometer goes to 0, and same with the RPM. i was like WTF.
anyone know what can cause this? blown fuse maybe?
well the ground wire from the valve cover is grounded to the chasis, not to the radiator support. i was doing a little investigating, and when my car has the e-brake on, all is well, but when i take it off and its just sitting and the lights are on, it makes a ding sound, then the gauges shut down and half the lights are on in the gauges.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivicb16 »</TD></TR><TR><TD CLASS="quote">well the ground wire from the valve cover is grounded to the chasis, not to the radiator support.</TD></TR></TABLE>
I just wanted to know if it was grounded at all, thanks for clarifying.
The e-brake switch sends a signal to the cluster to light up "BRAKE" light. Sounds like you have a short in the cluster, in my opinion.
thecruzs2007@yahoo.com
Sep 12, 2009 11:02 PM
hammerdgolfer
Jun 11, 2007 05:11 PM
