2000 Si camber kit
Old Mar 14, 2006 | 09:00 PM
mitmaks's Avatar
Default 2000 Si camber kit
Looking for Si camber kit. Where would be best place to buy one, best brand. Alignment shops wont do alignment on lowered Si.
Old Mar 14, 2006 | 09:22 PM
nighttrain33's Avatar
Default Re: 2000 Si camber kit (mitmaks)
For cheap, a lot of people do the washer method. They just use washers on the top bolt of the rear suspension to get it close. Ingalls sells camber kits as well as skunk2. There are many options available.
-Shane
Old Mar 14, 2006 | 09:23 PM
ekcivic9's Avatar
how much did you lower?! just ask them to set the toe straight.
Old Mar 14, 2006 | 09:24 PM
Default Re: (ekcivic9)
Though toe is the biggest problem when it comes to cornering, camber is going to affect the tires a lot too.
-Shane
Old Mar 14, 2006 | 10:13 PM
Turbo_y8's Avatar
Default Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">Though toe is the biggest problem when it comes to cornering, camber is going to affect the tires a lot too.
-Shane</TD></TR></TABLE>
false. The toe in/ toe out and air press. is the biggest prob. when you lower a car, it toes out.
go to the slammed thread and look at what they sa. there are guys slammed with no correction and getting everything out of their tires.
Old Mar 14, 2006 | 10:14 PM
bsixteen's Avatar
i bought an ingals camber kit for my SI. before i installed, i lost one side of it when i moved so i never installed. i did the cheap washer trick and after i installed my tein SS's my camber went to **** again in the back.
my question is..is there any permanent/better way to fix camber other than the Ingalls kit w/ the bolt and whatever else it came with? will aftermarket LCA's and such help? whats the reason for buying aftermarket LCA's other than replacing broken stock pieces.
ps don't mean to threadjack but this might help the OP also.
Old Mar 14, 2006 | 10:19 PM
Turbo_y8's Avatar
Default Re: (bsixteen)
yes, lca's help, they are shorter in length than the stock lca's, thus bringing the bottom of hub/tire assembly closer to the frame straighting the wheel.
have you tried adj. uca's in the front and rear?
Old Mar 14, 2006 | 10:38 PM
bsixteen's Avatar
i have not. how do you adjust the stock uca's?
Old Mar 14, 2006 | 10:40 PM
EK k kay's Avatar
Default Re: (tuck'd98)
No they're not shorter. Aftermarket LCA's only add swaybar holes for cars that don't have rear swaybar holes and the bling factor.
Old Mar 14, 2006 | 11:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">false. The toe in/ toe out and air press. is the biggest prob. when you lower a car, it toes out.</TD></TR></TABLE>
So, how was I false? When you lower a car, the toe is effected. The negative camber effects the toe, but having positive/negative toe does not definitely effect camber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">go to the slammed thread and look at what they sa. there are guys slammed with no correction and getting everything out of their tires.</TD></TR></TABLE>
Ummm, no. This will never happen.
-Shane
Old Mar 14, 2006 | 11:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen &raquo;</TD></TR><TR><TD CLASS="quote">i have not. how do you adjust the stock uca's? </TD></TR></TABLE>
You can't adjust the stock UCA's.
-Shane
Old Mar 15, 2006 | 12:00 AM
bsixteen's Avatar
so the best fix is the camber bolts from ingalls and other companies like them?
Old Mar 15, 2006 | 12:08 AM
I have personally never used the washer method, but the ingalls kit that I have worked perfectly.
-Shane
Old Mar 15, 2006 | 04:14 AM
bsixteen's Avatar
so http://shopping.lightningmotor...=1396
would be the best bet?
Old Mar 15, 2006 | 08:34 AM
Turbo_y8's Avatar
Default Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">No they're not shorter. Aftermarket LCA's only add swaybar holes for cars that don't have rear swaybar holes and the bling factor.</TD></TR></TABLE>
yes, they are shorter, side by side about a half inch. If they were just for sway bars they wouldnt make them for 96-00 and possibly newer since in 96 the lca's alreadys had hole for sway bars
Old Mar 15, 2006 | 08:36 AM
Turbo_y8's Avatar
Like i side when you lower a car the biggest prob is toein/ toe out.
With proper alignment on the toe, tires, yes will wear. but no wear near as fast. I went a year lowered at like 3.8 inchs, about 10,000 miles and my tires are fine. If you dont believe me ill go take a pic.
Old Mar 15, 2006 | 11:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">Like i side when you lower a car the biggest prob is toein/ toe out.
With proper alignment on the toe, tires, yes will wear. but no wear near as fast. I went a year lowered at like 3.8 inchs, about 10,000 miles and my tires are fine. If you dont believe me ill go take a pic. </TD></TR></TABLE>
It's not wearing at all on the inside of the tires? If not, then you're all good I guess. When I first put my Tiens on, I was getting a lot of wear on the inside of the tires until I got it aligned. Oh well.
-Shane
Old Mar 15, 2006 | 11:34 AM
ralphie14's Avatar
yes, they are shorter, side by side about a half inch. If they were just for sway bars they wouldnt make them for 96-00 and possibly newer since in 96 the lca's alreadys had hole for sway bars</TD></TR></TABLE>
Only certain brands are shorter than stock. Others are stock length, it all depends on the brand that you go with.
Old Mar 15, 2006 | 11:39 AM
Turbo_y8's Avatar
its all what you know. ill post a pic tomorow, im at work, but yea i mean slight wear but nothing bad, no cords, none of that ****!
Old Mar 15, 2006 | 12:08 PM
I8Stang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 &raquo;</TD></TR><TR><TD CLASS="quote">Only certain brands are shorter than stock. Others are stock length, it all depends on the brand that you go with.</TD></TR></TABLE>
Old Mar 15, 2006 | 12:50 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">It's not wearing at all on the inside of the tires? If not, then you're all good I guess. When I first put my Tiens on, I was getting a lot of wear on the inside of the tires until I got it aligned. Oh well.
Yeah, and when they aligned it they fixed the toe. Camber only exagerrates wear on the inside edge caused by toe. With 0 camber, your tires will still be 'scrubbing' the road surface, only evenly, so you're wearing out the whole tread, not just the inside edge.
I'm very low with my race suspesion on, well over -3* camber (so much you can see it, and the outside edge of the rear tire doesn't touch the ground sometimes) with zero toe, and absolutely no uneven wear. I'm getting better wear on my race tires than some get on their street sets.
Old Mar 15, 2006 | 08:01 PM
bsixteen's Avatar
which brand LCA's are shorter than stock?
EF_9
Apr 9, 2008 02:45 AM
Devious951
Apr 22, 2007 06:30 PM
ComputerJLT
12
Sep 2, 2004 10:37 PM
BADGUYNY
Oct 19, 2003 05:50 PM
