What cluster can I use with electronic VSS?
Old Mar 14, 2006 | 08:04 PM
b.d.racing's Avatar
Default What cluster can I use with electronic VSS?
I have an LS transmission with an electronic VSS and was wondering if there are any CRX clusters I can run with this? The VSS allowed me to run a 96-00 civic gauge cluster but its was in kmh and I didn't like it so I sold it when I stripped my car down for a makeover. Any inputs??????
Old Mar 14, 2006 | 08:07 PM
88YellowRexSi's Avatar
Default Re: What cluster can I use with electronic VSS? (b.d.racing)
Ive got a gsr cluster in my 88 si...if you get one I can send you the wiring schematic...
Old Mar 14, 2006 | 08:24 PM
b.d.racing's Avatar
Default Re: What cluster can I use with electronic VSS? (88YellowRexSi)
Ahh very nice but will my VSS work with a GSR cluster and please do send me the wiring schematic. Anymore inputs?
Old Mar 14, 2006 | 11:34 PM
red_EF9Si's Avatar
any DC, EK, EG, & CRV cluster will work.
Old Mar 14, 2006 | 11:41 PM
Ak_ef9's Avatar
Default Re: (red_EF9Si)
Type r cluster will work. its what I got
http://www.angelfire.com/dc/oregonimport/gsr.html
https://honda-tech.com/zerothread?id=458873
The only problem I had was the wiring for the vss was all different. instead of power signal ground it was signal power ground.
Old Mar 15, 2006 | 06:00 AM
b.d.racing's Avatar
Thanks for all the help. So When I get this cluster I need the plugs so I can cut and splice the new with the old?
Modified by b.d.racing at 7:17 AM 3/15/2006
Old Mar 15, 2006 | 01:49 PM
red_EF9Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b.d.racing &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the help. So When I get this cluster I need the plugs so I can cut and splice the new with the old?
Modified by b.d.racing at 7:17 AM 3/15/2006</TD></TR></TABLE>
yup, you will need the blue plugs. most clusters don't come with them so it may be a pain in the neck trying to locate some. i lucked out and found a complete dash wiring bundle on ebay for 10 bux
french_yogi
Apr 18, 2011 06:24 PM
Midori Green
Jun 25, 2007 03:03 PM
importboi22
May 31, 2004 10:32 PM
blackteg
Dec 31, 2003 02:20 PM
EARLdaSQUIRREL
15
Jun 10, 2003 04:49 PM
