Where do I get a Honda Test Harness? : 07LAJ-PT3010A
Old Mar 14, 2006 | 02:53 PM
gilligan354's Avatar
Default Where do I get a Honda Test Harness? : 07LAJ-PT3010A
In my manual it says connect the ECU to the test harness. Where do I get this test harness and how much is it?
Old Mar 14, 2006 | 03:38 PM
Jedi_Sol's Avatar
Default Re: Where do I get a Honda Test Harness? : 07LAJ-PT3010A (gilligan354)
Are you talking about the tool to use to pull Check Engine Light codes from the ecu?
If that's the case, all you need is a paper clip. There is a plug near the ecu that has one green wire and a brown wire coming out of it. (There might be a neon green cover over the plug if youve never pulled a code from the ecu before).
With the key in the "OFF" position in the ignition, take the paper clip and bend it into a "U" shape and stick it into the plug to complete the circuit. Turn the key into the "ON" position and if you did it right, you will see the "CHECK ENGINE" light flash. A long flash is the first digit, a short flash is the second digit. For example.
!........!.....!!..................!.............! .......!!.... = 22
Two long flashes, followed by two short flashes. If there are multiple codes there will be a long pause in between.
James
Old Jul 31, 2008 | 09:29 AM
classicalgq's Avatar
did you get any help with finding a test harness? b/c i have a service manual and it is needed to test for just about evey problem. What did you end up doing??
Old Feb 8, 2009 | 06:04 PM
my_hidden_romance's Avatar
Old Feb 8, 2009 | 06:43 PM
NOFX's Avatar
H-T White Ops
I used Google. This was the fourth result.
http://hondamarketplace.com/showthread.php?t=2316802
theEG6
Dec 17, 2013 07:33 AM
holmesnmanny
Dec 18, 2011 12:51 PM
vtecn8ive
Jun 22, 2005 08:59 AM
hankd
Aug 23, 2003 03:22 AM
_Endless_
Aug 28, 2002 06:10 PM
