check engine light on ls swap
Old Mar 14, 2006 | 12:27 PM
gofastr110's Avatar
Default check engine light on ls swap
i got a 94 civic with a ls(b18a1) swap. the engine light is on. at idle it runs rich and high in RPMs it runs lean. there is no pop or studering, runs fine. any thoughts?
Old Mar 14, 2006 | 12:35 PM
averyvm's Avatar
You should check the ECU for codes
Old Mar 14, 2006 | 12:36 PM
gofastr110's Avatar
Default Re: (averyvm)
my computer is a p75. where is the light on it because i didnt see one?
Old Mar 14, 2006 | 01:25 PM
SVOboy's Avatar
https://honda-tech.com/zerothread?id=1171263
Use this method to get the code(s).
Old Mar 14, 2006 | 02:04 PM
gofastr110's Avatar
Default Re: (SVOboy)
hey thnx man i will try that as soon as my car comes back. let a friend go to the store in it.
Old Mar 14, 2006 | 02:24 PM
mwieczorek43's Avatar
Default Re: (gofastr110)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gofastr110 &raquo;</TD></TR><TR><TD CLASS="quote">hey thnx man i will try that as soon as my car comes back. let a friend go to the store in it.</TD></TR></TABLE>
man
You let a friend drive your newly-swapped code-throwing car?!! He gonna beat it, and blow it up.
Old Mar 14, 2006 | 03:28 PM
EG93si's Avatar
Default Re: (mwieczorek43)
this is what happens when you loan your car to a friend to go to the store inhttps://honda-tech.com/zerothread?id=1559348
Old Mar 14, 2006 | 07:57 PM
blackhat1's Avatar
Default Re: (EG93si)
what were you thinking
MRsol
Engine Management and Tuning
Dec 5, 2009 03:45 PM
dohc_vtec_acura1
Dec 27, 2007 01:35 PM
TastyTuner
Mar 15, 2006 05:29 PM
CivicEx95
Apr 28, 2002 02:27 AM
