lsd or open diff
Old Mar 12, 2006 | 02:44 PM
LSsteinEG's Avatar
Default lsd or open diff
Which one causes more stress to the tranny and axles when drag racing?
Old Mar 13, 2006 | 06:34 AM
Lsos's Avatar
Default Re: lsd or open diff (LSsteinEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSsteinEG &raquo;</TD></TR><TR><TD CLASS="quote">Which one causes more stress to the tranny and axles when drag racing?</TD></TR></TABLE>
I imagine the LSD would cause more stress to they tranny, just because it is putting more power to the ground, and probably because the initial "jolt" would be greater.
I wouldn't think it makes a difference to the axles.
I'm just thinking here, though. No actual experience.
Old Mar 13, 2006 | 07:36 AM
LSsteinEG's Avatar
Default Re: lsd or open diff (Lsos)
yeah.. I was just wondering. If thats the case I would rather run open diff.
Old Mar 13, 2006 | 08:39 AM
Lsos's Avatar
I don't think the stress would be that much greater, and I don't think it's a valid reason for running on an open differential. Running on quarter throttle would also put less stress on the transmission, but I wouldn't advise it as a good racing strategy, especially when the thing is built to take like 5x any stress it will ever see. Honda transmissions aren't generally considered to be a weak link.
Old Mar 13, 2006 | 12:07 PM
1bad-eg's Avatar
Which one would you prefer. 1 wheel wonder or both tires hooking and the car moving? Me personally, lsd all the way.
Old Mar 13, 2006 | 06:38 PM
Top Ramen's Avatar
Default Re: lsd or open diff (1bad-eg)
I don't really understand your question - why the hell would you drag with an open diff if you have a choice?
Old Mar 14, 2006 | 11:49 AM
LSsteinEG's Avatar
Default Re: lsd or open diff (Top Ramen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen &raquo;</TD></TR><TR><TD CLASS="quote">I don't really understand your question - why the hell would you drag with an open diff if you have a choice? </TD></TR></TABLE>
Alot of ppl on the forum run open diff and have a choice. Im just trying to get the truth behind what causes more stress on the transmissions. LSOS sounds right though with his previous reply.
Old Mar 14, 2006 | 02:46 PM
Top Ramen's Avatar
Alot of ppl on the forum run open diff and have a choice. </TD></TR></TABLE>
Its slower. Period. I don't think you are going to find anyone who races with any serious intent who wouldn't choose an LSD over an open diff.
As far as 'stress' , ANY performance mod that adds power adds stress.
Old Mar 14, 2006 | 02:50 PM
1bad-eg's Avatar
As far as 'stress' , ANY performance mod that adds power adds stress.</TD></TR></TABLE>
Old Mar 14, 2006 | 08:45 PM
Lsos's Avatar
Right. If you want to not run LSD because of stress on the tranny, you might as well take out the engine, too. The tranny will practically last forever.
It kind of defeats the purpose of what you are trying to do though. Seriously, concentrate on the things that matter first. The tranny is the last thing you have to worry about.
Old Mar 14, 2006 | 08:53 PM
Creator's Avatar
I run a 89 civic with an LS motor.....and a y1 LSD tranny. Everyone is right if you want to drag race and have a choice definately go with LSD. Unfortunatley with my car and the grippy tires I run I've run into all sortsa problems. Ripped one engine mount off the frame. Cracked my rear engine cradle welded it back and recracked and broke welds on it (will replace it soon).
So the real question would be....would I still go with the LSD...with out a doubt.
Old Mar 17, 2006 | 01:04 AM
raceACCORDingly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen &raquo;</TD></TR><TR><TD CLASS="quote">Its slower. Period. I don't think you are going to find anyone who races with any serious intent who wouldn't choose an LSD over an open diff.
Except for the kid that lost his civic on Pinks.
Old Mar 17, 2006 | 12:38 PM
Double Agent's Avatar
Let's clear up the stress issue. LSD is better for the tranny in race conditions, it distributes power evenly. An open diff only spins one tire and actually wears out the differential quicker.
LSD does however, does put more stress on axles b/c there is little or no give for either side.
As far as which is better for drag, LSD all the way.
Old Mar 17, 2006 | 03:13 PM
Lsos's Avatar
Default Re: lsd or open diff (Double Agent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Double Agent &raquo;</TD></TR><TR><TD CLASS="quote">Let's clear up the stress issue. LSD is better for the tranny in race conditions, it distributes power evenly. An open diff only spins one tire and actually wears out the differential quicker.
As far as which is better for drag, LSD all the way.</TD></TR></TABLE>
The open differential is more prone to fail, from what I understand. But, I would think that the actual gears in the transmission are stressed more with an LSD. Again, not that this is really an issue unless you're making so much power that you already upgraded the clutch, axels, tires, engine, engine mounts, frame, and pretty much everything else.
dragaholic
12
Jul 20, 2006 08:07 PM
deesracer
Jul 14, 2004 04:02 AM
teg92
Feb 24, 2004 06:56 PM
20lb.teg
Oct 29, 2003 06:12 PM
rig9896
Oct 22, 2003 05:07 PM
