GSR swap starts and revs fine that dies...help!
Old Mar 11, 2006 | 02:06 PM
trecool44's Avatar
Default GSR swap starts and revs fine that dies...help!
I just finished a obd2 jdm gsr swap in a 98 hatch. It starts fine and you can rev it fine, but the second you let off the throttle , it dies. It doesnt rev up at all when you start it, like the warm up rpm. It just starts and dies. What could be the problem? Thanks in advance.
Old Mar 12, 2006 | 04:25 AM
trecool44's Avatar
Default Re: GSR swap starts and revs fine that dies...help! (trecool44)
bump, i need some help
Old Mar 12, 2006 | 04:44 AM
john666's Avatar
sensors all hooked up correctly ?
Old Mar 12, 2006 | 05:28 AM
Rock Meathammer's Avatar
Default Re: GSR swap starts and revs fine that dies...help! (john666)
Dirty throttle body? Iac working/hooked up?
Old Mar 12, 2006 | 05:58 AM
mikeg015's Avatar
Check the iac. That sensor and another sensor on that motor have the same plug, maybe you got them mixed up.
Old Mar 12, 2006 | 09:41 AM
ReDHaTcHyGuy's Avatar
Default Re: (mikeg015)
what harness did you use? if the y7 harness did ur do the iac fix...?
Old Mar 12, 2006 | 04:37 PM
trecool44's Avatar
bump
Old Mar 12, 2006 | 05:00 PM
brg2nr's Avatar
TPS? Thats my best guess. Hard to say without getting ahold of the car and seeing for myself. Any engine codes?
Eg6_k20
Engine Management and Tuning
Sep 7, 2011 01:01 PM
ah527venom
Jun 7, 2010 11:58 AM
singleslamwonderman
22
Sep 2, 2008 07:01 PM
mastakmk
12
May 25, 2007 10:45 PM
hatch101
Jun 23, 2003 07:27 PM
