What exhaust to use with H22 swap in 5th Gen?
Old Mar 11, 2006 | 07:08 AM
Knightmare69's Avatar
Default What exhaust to use with H22 swap in 5th Gen?
I'm possibly ddoing a H22 swap into my gf's 96 but we did alot of work in regards to her exhaust for the F22, so I'm wondering, if I drop in the H22, will the H22 header bolt on to the cat converter of the F22?
FYI- the H22 comes with a DC-sport 2pc and we have a bolt on Random Tech Cat in place of the stock F22 and Magnaflow cat-back.
I tried to search but my results came back negative.
Old Mar 11, 2006 | 10:07 AM
philadd's Avatar
Default Re: What exhaust to use with H22 swap in 5th Gen? (Knightmare69)
I believe you'd need to have the header re-welded so that it can bolt up to the cat. Now would be a good time to change to a larger collector.
Old Mar 11, 2006 | 03:33 PM
dungeonKing's Avatar
you need to get a test pipe that has the proper flanges on either side of the pipe. you may have to cut out or add a section of pipe to the back side of the exhaust piping.
Old Mar 12, 2006 | 04:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">I believe you'd need to have the header re-welded so that it can bolt up to the cat. Now would be a good time to change to a larger collector.</TD></TR></TABLE>
K, basically if I take the flange off the aftermarket header from the F22 and weld it in place of the DC Sport header from the H22 I can just bolt everything up? I have a random Tech cat and a Magnaflow 2.25 cat-back already on the car.
Old Mar 13, 2006 | 11:57 AM
philadd's Avatar
Default Re: (Knightmare69)
No, the length of the header is different.
Old Mar 14, 2006 | 12:01 PM
madrrio's Avatar
the f22 header looks like this O OO O
the h22 header looks like this O O O O
Old Mar 14, 2006 | 12:10 PM
philadd's Avatar
Default Re: What exhaust to use with H22 swap in 5th Gen? (madrrio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madrrio &raquo;</TD></TR><TR><TD CLASS="quote">the f22 header looks like this O OO O
the h22 header looks like this O O O O</TD></TR></TABLE>
Yes, we know that. That is not what we were concerned about.
Old Mar 14, 2006 | 12:49 PM
fw190bvi's Avatar
Default Re: What exhaust to use with H22 swap in 5th Gen? (philadd)
length of the h22 header is different. your best bet would probably get a cat designed for the H header, bolt that up, and then re weld (if neccesary) to an Accord mid pipe. it may be more costly, but you could change out exhausts to something from a CD6 accord. alot of manufacturers made/make exhausts for that car in Japan, but not for the f22 in the US (example, apexi N1)
X01Michael
Jul 4, 2012 06:40 AM
jdm b16 eg
Oct 10, 2011 09:59 AM
jaysome01
May 12, 2009 08:34 AM
972drcordex
Jul 17, 2005 08:56 PM
The DX Rex
Jan 23, 2005 09:10 PM
