H22 civic cat-back??
i have a 94 h22 hatch with an egay header, for now... my question is will a civic cat back exhaust pipe be long enough to bolt up to the header?? the h22 header is longer than a d/b series so i thought maybe it could be as long as a stock exhaust mani and cat. therefore a civic cat back may mount up?? my exhaust is leaking bad from the crappy welds the muffler shops around here do. i would just like to buy a cat back exhaust. but want to make sure it will work before i pay for it. any help is appreciated. Thanks
Re: H22 civic cat-back??
I had to get a custom pipe welded from my H22 aftermarket manifold to my Apexi WS2 cat back as a standard "test pipe" or OE cat would not fit. The pipe I needed was about 11" long if I recall correctly.
You can always get one of those adjustable test pipes, adjust to where you need it, and just have the shop weld it together.
H22ACiViC
01-29-2002 05:50 PM
