is it possible???
Old Mar 9, 2006 | 01:58 PM
eg2phosizzle's Avatar
Default is it possible???
is it possible to arc weld stainless steel 2" piping onto and std cast iron manifold to run and external wastegate??? i just wanted to know if its weldable with an arc welder and will it hold...thanks in advance
Old Mar 9, 2006 | 06:25 PM
ManBearPig4silly's Avatar
Default Re: is it possible??? (eg2phosizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2phosizzle &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to arc weld stainless steel 2" piping onto and std cast iron manifold to run and external wastegate??? i just wanted to know if its weldable with an arc welder and will it hold...thanks in advance </TD></TR></TABLE>
that would be one unholy bastard of a weld to do with stick but if you are brave enough to attempt it use NIrod. Don't get mad if it doesn't turn out that well. Tig with a nickel rod is the way to go.
Old Mar 9, 2006 | 06:27 PM
Niles's Avatar
If you're looking to save a buck, do the fit up, and take it to someone who has welded to cast iron before, the fitup is where most of the money usually goes...
I'm with I4sillypower it would be very tough.
also the clubs in his profile are hilariously awesome
vy3tnamezz
Welding / Fabrication
Sep 9, 2008 06:38 PM
RSWEPN
Feb 15, 2008 10:38 PM
eclypzex
Jan 28, 2008 06:58 PM
Egone
Feb 6, 2004 02:28 PM
slooogsr
Nov 5, 2003 02:59 PM
