ZEX Problem Help!
Old Mar 31, 2002 | 02:46 PM
nsxmatt's Avatar
Default ZEX Problem Help!
Installing a zex kit on a Friends 96 Civic HX. Install went smoothly (not my first kit) but it does something wierd now that it's done..
When you switch the ARM switch inside the car the nitrous is activated. No matter what, even if you are at idle it sprays. It's supposed to activate at WOT. We reset and set the "box" about 10 times with no luck. Thwe white wire is on the right TPS wire (the one that voltage changes when throttle is pressed) and the box's lights do what they are supposed to do when you set it.
We think ZEX sent us a bad box but I can't be sure, any other suggestions from people who have the kit?
Old Mar 31, 2002 | 03:09 PM
Plan B's Avatar
Default Re: ZEX Problem Help! (nsxmatt)
All i can think of is to try to reset it again. It should be the middle tps wire, not sure what to tell you there. Good luck, i've sold dozens of these things and never seen one come back yet.
Old Mar 31, 2002 | 03:19 PM
nsxmatt's Avatar
Default Re: ZEX Problem Help! (Plan B)
Yeah, i've reset it I can't tell you how many times. The TPS signal wire is measuring .5 to 4.5 and the wire has a good connection. We tested it and the nitrous works fine but you have to flip the switch in gear and turn it back off before you shift (not good ).
I guess i'll call ZEX tomorrow and see what they can do
Old Apr 1, 2002 | 03:47 AM
Mista Bone's Avatar
D Tranny Guru
Glad I have a first generation ZEX kit, no setting or lights.
No problems either.
UrVtecIsLoud
Oct 18, 2006 06:49 PM
Danziver
Jul 24, 2006 09:25 AM
jay_powell
Mar 12, 2004 07:54 PM
dragonrcr
Sep 23, 2002 10:35 AM
