zex nitrous
Old Mar 11, 2004 | 04:44 PM
jay_powell's Avatar
Default zex nitrous
i just finished install on zex dry kit but dont have all directions and dont know how to program box for wide open throttle...please help
Old Mar 12, 2004 | 02:01 PM
sl0w-m0's Avatar
Default Re: zex nitrous (jay_powell)
I think you wire up the Barny Box to your TPS sensor and with the nitrous bottle CLOSED turn the ignition on(not the car). Put the gas pedal to the floor so the Barny Box picks up the WOT voltage and it should set itself. Somebody correct me if i'm wrong please. Hope I helped.
Old Mar 12, 2004 | 04:43 PM
SwampThing's Avatar
i have the directions in my car i have the same kit. it's already set for WOT you have to put the wires to the arming switch. then when you flip the switch and hit WOT it's activated. expect a second delay(seems longer then that) for it to kick in, or maybe thats my tires spinning but yeah so far im happy with the kit. 55 shot jet should last you about 15 races i think. i wouldnt do more then 4 runs back to back, let your car cool down before you go out and slaughter more people.
Old Mar 12, 2004 | 07:54 PM
boosted-delslow's Avatar
There is no need to set the box....all that you have to do to check that you have the right TPS wire is turn the key on and put the gas pedal to the floor. If you have the correct wire you will hear the selonoide in the zex box click.
UrVtecIsLoud
Oct 18, 2006 06:49 PM
rice crispies
Jun 7, 2004 10:44 AM
TurboT
Nov 9, 2003 04:50 PM
nsxmatt
Apr 1, 2002 03:47 AM
