bogging vtec-e
ok so recently i ran out of gas and have been running it all the way down to E. so when i reach around 3000rpm (vtec-e kick in point) it boggs and feels like im being pulled back. would this be due to a gas related problem? if so i need a good fuel injector cleaner.
Its sounds like you need a new fuel filter. When was the last time you changed your oil? I have a 97 HX and I had the same problem but all I did was change oil and my v-tec kicked hardcore. My sister wrecked my car though so I am driving my old 89 LX-i Accord around now. But check your oil and your fuel filter and hopefully that will fix the problem.
Ed
Ed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaciv95VX »</TD></TR><TR><TD CLASS="quote">U go from Very E to Fully F ?</TD></TR></TABLE>
im saying even with a full tank of gas it does the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhettoStyle »</TD></TR><TR><TD CLASS="quote">Its sounds like you need a new fuel filter. When was the last time you changed your oil? I have a 97 HX and I had the same problem but all I did was change oil and my v-tec kicked hardcore. My sister wrecked my car though so I am driving my old 89 LX-i Accord around now. But check your oil and your fuel filter and hopefully that will fix the problem.
Ed</TD></TR></TABLE>
havent changed my oil in a while ill try that. sorry to hear bout the car.
Fuel pump, and or flter is takeinga **** on you.. when u run a car down to e like that your heating up the fuelk pump, it needs that fuel tyo keep it cool.. thus by you running it to E, its not getting the proper cooling needed, also your creating avacum in your tank as well..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhettoStyle »</TD></TR><TR><TD CLASS="quote"> I had the same problem but all I did was change oil and my v-tec kicked hardcore.</TD></TR></TABLE>
wish i had that kind of vtec in my hx. mine only goes from slow to kinda-slow...
b16gurl
Apr 17, 2006 05:10 AM
SiMateoAko
11
Feb 23, 2006 08:23 AM
