Its running
Old Mar 31, 2002 | 10:42 AM
zCivic's Avatar
Default Its running
I got the wiring straightened out. It runs perfect. Have just one more problem. My transmission will not go into 4th gear. It is completly block. Any fixes or ways to check to see what the problem is other then a new transmission. Thanks for all the help....
Old Mar 31, 2002 | 11:36 AM
chhuong's Avatar
Default Re: Its running (Lil Cs Zc)
are you using an adjustable shift linkage, if so check that.
Old Mar 31, 2002 | 11:38 AM
zCivic's Avatar
Default Re: Its running (chhuong)
nope not adj. Its just the regular linkage. It was a D16Z6 into a 90 hatchback
Old Mar 31, 2002 | 11:41 AM
zcivic91's Avatar
Default Re: Its running (zCivic)
well did u have the tranny in ur car working before or is it a new one? also check the oil in it and drive it arond maybe u just gotta get it moving again to select the gear...u would hope.
Old Mar 31, 2002 | 11:50 AM
zCivic's Avatar
Default Re: Its running (zcivic91)
Well It sat for a while the guy told me it was fine. Took his word for it. When it was on the jack stands and put honda MTF it would go into 4th gear when lowered it on the ground it blocked it again...
Old Mar 31, 2002 | 05:58 PM
4gvtec's Avatar
got it running right,yes! nothing better than your swap running ****!
Freshdot
Transmission & Drivetrain
Jun 2, 2011 11:13 AM
dtegra90
Jun 26, 2007 09:56 AM
CHAMPwhteEK
11
Mar 27, 2006 02:46 PM
akirab16
Oct 10, 2004 03:35 PM
DC24jooo
Jul 6, 2004 08:46 PM
