How does a cylinder missfire code get detected
Old Mar 8, 2006 | 07:21 AM
11secEk's Avatar
Default How does a cylinder missfire code get detected
My cars been giving me a cylinder #3 missfire and its running great no missfire i feel... how is it detected to the ECU, maybe a sencors going bad??
Tony
Old Mar 8, 2006 | 11:34 AM
drdisco69's Avatar
Default Re: How does a cylinder missfire code get detected (11secEk)
There is a crank fluctuation sensor on the OBD2 cars. It's located on the oil pump, and it detects small changes in the engine speed, way below what you can feel. For misfires, suspect the ignition system first. Assuming you don't just have a bad tank of fuel, make sure all igntion parts are OEM in good condition. This includes plugs, wires, distributor cap and rotor.
Old Mar 8, 2006 | 03:02 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: How does a cylinder missfire code get detected (drdisco69)
You can also check the valve lash adjustment. Too tight can cause a misfire at low RPM. Bent valves also have the same effect. You won't have bent valves unless you misshifted and overreved the engine. Fuel injectors are also suspect.
Modified by Dogginator at 10:00 PM 3/8/2006
Old Mar 8, 2006 | 05:18 PM
Runnerdown's Avatar
Default Re: How does a cylinder missfire code get detected (Dogginator)
no, he is right. US obd2 cars have the sensor located on the oil pump and read off the crank gear. more accurate pickup.
Old Mar 8, 2006 | 06:00 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: How does a cylinder missfire code get detected (Runnerdown)
You guys are correct. I like learning stuff.
Old Mar 8, 2006 | 06:22 PM
11secEk's Avatar
thanx-ill check it out!!
Old Mar 8, 2006 | 08:14 PM
Smoke_em's Avatar
From: Inland empire, E.L.A, Douglasville GA, ca, u.s
also u can get resistance between injector to see if its fuel misfire if resistance is the saem across all injector or within specs then look at mechanical probelms or electrical like ur ignition system liek they said earlier
Old Mar 11, 2006 | 07:51 PM
11secEk's Avatar
Default Re: How does a cylinder missfire code get detected (Smoke_em)
Well after some $$ and time... i think i have a bad injector on my hands... GAY!! anyone kno where i can get one
Old Mar 12, 2006 | 05:30 AM
Dogginator's Avatar
Daisy... Daisy...
What is wrong with the injector? Is it clogged, leaking, or spraying erratically? You may want to try some fuel injector cleaner. These can also be cleaned, but used replacements are probably cheaper. If you need new ones, try the classifieds.
ericdachampion86
Nov 4, 2007 11:14 AM
finest_GSR
Nov 19, 2005 10:30 AM
97vtecpower
Nov 11, 2005 08:57 PM
97vtecpower
Nov 11, 2005 01:46 PM
91_HB
13
Jun 27, 2005 10:21 AM
