major car problems
Old Mar 8, 2006 | 06:11 AM
dragonjay006's Avatar
Default major car problems
my civic with a 95 ls is running way 2 rich. i have the b&m fuel gauge on it and it says that im getting 65-70 psi of fuel on a stock motor. i pulled the plugs they are black and smell like gas. so far iv changed the pump, adjustable regulater,stock regulater, filter, checked all the lines. when i turn on the car it idles fine starts fine but when i give it gas it bogs i checked the timing over and over but still the same problem. if anybody can help let me know. thanks
ps. the motor is in a 96 civic obd2
Old Mar 8, 2006 | 06:44 AM
IHateJDM's Avatar
Default Re: major car problems (dragonjay006@yahoo.com)
so you have an adjustable FPR and you still can't get the fuel pressure below 65 psi?
Old Mar 8, 2006 | 07:04 AM
Default Re: major car problems (IHateJDM)
correct
Old Mar 8, 2006 | 07:09 AM
cxtengoku's Avatar
what ecu are u using?
Old Mar 8, 2006 | 07:25 AM
Default Re: major car problems (cxtengoku)
97 ls
Old Mar 8, 2006 | 07:27 AM
schardbody's Avatar
i would say you have a blockage in the return line or a bad regulator, but someone else will come up with some other ideas. thas all i can think of off the top of my head.
Old Mar 8, 2006 | 07:41 AM
IHateJDM's Avatar
Default Re: (schardbody)
what kind of fuel pump are you running?
Old Mar 8, 2006 | 10:33 AM
Default Re: (IHateJDM)
stock 97 ls pump
Old Mar 8, 2006 | 10:36 AM
IHateJDM's Avatar
Default Re: (dragonjay006@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonjay006@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">stock 97 ls pump </TD></TR></TABLE>
then I would guess your return line is clogged.
Old Mar 8, 2006 | 11:29 AM
nah i checkd its fine
dragonjay006
Nov 4, 2014 08:16 PM
MAYHEM
Mar 1, 2005 09:07 PM
boosted_zc
Apr 22, 2004 01:21 PM
rasta420
Mar 24, 2003 09:20 PM
